Different RFID-Codes via different sketches...but which result is true?
I have tested some sketches with the same rfid-reader and there same tags but there are some differences in the resulting tag codes. At first I have tried this sketch
http://www.pagemac.com/source.php?f=azure/progs/arduino_hid_wiegand.ino
with the following results:
Tag1 → 244 49666
Tag2 → 129 42492
Then I have tried a modified Version from
http://www.thebox.myzen.co.uk/Hardware/Crazy_People_files/Crazy.zip
where the results are:
Tag1 → 50547704 respective 385 9724
Tag2 → 32080900 respective 244 514
this is the modified code:
/* Crazy People
 * By Mike Cook April 2009
 * Three RFID readers outputing 26 bit Wiegand code to pins:-
 * Reader A (Head) Pins 2 & 3
 * Interrupt service routine gathers Wiegand pulses (zero or one) until 26 have been recieved
 * Then a sting is sent to processing
volatile long reader1 = 0;
volatile int reader1Count = 0;
void reader1One(void) {
  reader1Count++;
  reader1 = reader1 << 1;
  reader1 |= 1;
void reader1Zero(void) {
  reader1Count++;
  // Attach pin change interrupt service routines from the Wiegand RFID readers
  attachInterrupt(0, reader1Zero, RISING);//DATA0 to pin 2
  attachInterrupt(1, reader1One, RISING); //DATA1 to pin 3
  delay(10);
  // the interrupt in the Atmel processor mises out the first negitave pulse as the inputs are already high,
  // so this gives a pulse to each reader input line to get the interrupts working properly.
  // Then clear out the reader variables.
  // The readers are open collector sitting normally at a one so this is OK
  for(int i = 2; i<4; i++){
  pinMode(i, OUTPUT);
   digitalWrite(i, HIGH); // enable internal pull up causing a one
  digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
  pinMode(i, INPUT);
  delay(10);
  // put the reader input variables to zero
  reader1 = 0;
  reader1Count = 0;
  //digitalWrite(13, HIGH);  // show Arduino has finished initilisation
  if(reader1Count >=26){
//Serial.print(" Reader 1 ");
Serial.println(reader1,DEC);
 // Serial.println("A");
 //Serial.println(reader1& 0xfffffff);
 int serialNumber=(reader1 >> 1) & 0x3fff;
 int siteCode= (reader1 >> 17) & 0x3ff;
 Serial.print(siteCode);
 Serial.print("  ");
 Serial.println(serialNumber);
  reader1 = 0;
  reader1Count = 0;
  delay(10);
The code from the Crazy People includes the parity bits at the start and end of the code. This is not normally considers as part of the token value and will be excluded from the first example. For Crazy people it did not matter so I didn't bother checking the parity and just used the whole number.
