I am wondering if I can invert the output of D10 (0C1B), so it is 180 degrees out of phase with D9 (0C1A). Using Arduino Uno Rev 3.
Thanks in advance...
my code:
#define myOutputPin 9
#define mynotOutputPin 10
void setup ()
pinMode (myOutputPin, OUTPUT);
pinMode (mynotOutputPin, OUTPUT);
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 80; // for 100KHz
TCCR1A |= (1 << COM1A0);
TCCR1A |= (1 << COM1B0);
TCCR1B |= (1 << WGM12);
TCCR1B |= (1 << CS10);
Yes. You've already done that. You have set D9 and D10 to toggle at the top of the count (COM1A0 and COM1B0 set). Just digitalWrite(9, LOW); digitalWrite(10, HIGH); in setup(). Since they both toggle at the same time they will remain 180° out of phase.
Edit:
Also, set OCR1B to the same value as OCR1A.
The data sheet only mentions OC1A for output in CTC mode, not the B channel. Did I miss something?
I think it will work if OCR1B is set the same as OCR1A. The datasheet says that the COM1B0 and COM1B1 bits work in CTC mode.
DrDietrtrich - Thank you very much I will experiment with Fast PWM mode..
In regards to your second comment I could not find it in the data sheet either but was able to activate D10. Hence one of the reasons for my post.
Thanks again!
" Yes. You've already done that. You have set D9 and D10 to toggle at the top of the count (COM1A0 and COM1B0 set). Just digitalWrite(9, LOW); digitalWrite(10, HIGH); in setup(). Since they both toggle at the same time they will remain 180° out of phase.
Edit:
Also, set OCR1B to the same value as OCR1A"
Thank you John! I'm going to try that when I get back to the laboratory...
COM1B0 outputs the same rate as set in OCR1A, but the cool thing is I can set a different rate in OCR1B. That yields different frequencies on the same timer.
In the datasheet I have (DS40002061A) it's on Page 140:
When the OC1A or OC1B is connected to the pin, the function of the COM1x1:0 bits is dependent of the WGM13:0 bits setting. Table 16-1 shows the COM1x1:0 bit functionality when the WGM13:0 bits are set to a Normal or a CTC mode (non-PWM).
Table 16-1. Compare Output Mode, non-PWM
| COM1A1/COM1B1 |
COM1A0/COM1B0 |
Description |
| 0 |
0 |
Normal port operation, OC1A/OC1B disconnected. |
| 0 |
1 |
Toggle OC1A/OC1B on Compare Match. |
| 1 |
0 |
Clear OC1A/OC1B on Compare Match (Set output to low level). |
| 1 |
1 |
Set OC1A/OC1B on Compare Match (Set output to high level). |
TomGeorge - Yes sir, I had it running but both pins had the same phase relationship. It will be perfect after I invert D10's signal.
No, you can't. The frequency of both is controlled by OCR1A. You can set OCR1B to a lower value so it toggles earlier in the cycle if you want a phase difference less than 180°.
Johnwasser,
"No, you can't. The frequency of both is controlled by OCR1A. You can set OCR1B to a lower value so it toggles earlier in the cycle if you want a phase difference less than 180°."
I will double check when I get to the lab later, but last night I'm pretty certain I achieved that. And of course the timing was related. It was a bit of a late night... lol
Stay tuned and thanks again for your assistance!!!
