Hi.
Please forgive me as its my first post here.. Not asking for help
I have been working on getting a Differential drive for my project. Lots of snippets of code around but not what I wanted for my project.
/* With a little help from :-
 http://home.kendra.com/mauser/joystick.html
 http://forum.arduino.cc/index.php?topic=114063.0
 Gives me 100% forward speed and 50% revirse speed.
 1.Get X and Y from the Joystick, do whatever scaling and calibrating you need to do based on your hardware.
 2.Invert X
 3.Calculate R+L (Call it V): V =(100-ABS(X)) * (Y/100) + Y
 4.Calculate R-L (Call it W): W= (100-ABS(Y)) * (X/100) + X
 5.Calculate R: R = (V+W) /2
 6.Calculate L: L= (V-W)/2
 7.Do any scaling on R and L your hardware may require.
 8.Send those values to your Robot.
 9.Go back to 1.
int Deadzone = 4;
int coordX = 0;Â Â Â Â Â Â Â Â Â // variable to read the value from the analog pin 0
int coordY = 0;Â Â Â Â Â Â Â Â Â // variable to read the value from the analog pin 1
 coordY = analogRead(2); //cordY min = 7, Mid = 519, Max = 1018
 coordX = analogRead(3);  //cordX Min = 3, Mid = 522, Max = 1020
 int coordXmapped = map(coordX, 0, 1023, 100, -100); //maps from 0-1023 POT range to -100 - 100 range of formula
 int coordYmapped = map(coordY, 0, 1023, 100, -100); //maps from 0-1023 POT range to -100 - 100 range of formula
 int coordXinvert = (coordXmapped * -1);
 int v = ((100 - abs(coordXinvert)) * (coordYmapped / 100) + coordYmapped);
 int w = ((100 - abs(coordYmapped)) * (coordXinvert / 100) + coordXinvert);
 int rightwheel = ((w - v) / 1);
 int leftwheel = ((v + w) / 1);
 int Left_motor = abs(leftwheel) < Deadzone ? 0 : leftwheel;   // add dead zone from Joystick
 int Right_motor = abs(rightwheel) < Deadzone ? 0 : rightwheel;  // add dead zone from Joystick
Â
Well Iv'e managed to insert my code in the correct manner.
As im'e new to the Arduino I would like to be told what right and what's NOT right.
Hope someone finds my work usefull.
Regards Antony.
