I am using differential quadrature encoder which is having rs422 differential output.
To interface with arduino I am using MC3486 line receiver IC output of MC3486 is given to arduino interrupt.
But I am getting values at arduino end even if motor is not moving.
knowledge:
I see one of 4 possible serial outputs on the chip. Why are sending serial data to an interrupt pin? A schematic of your project is certainly needed.
Paul
Attached is the schematic.
Output of IC 3486-
DIFFERENTIAL INPUTS ENABLE OUTPUT
A–B Y
VID ≤ 0.2 V H H
–0.2 V < VID < 0.2 V H ?
VID ≤ –0.2 V H L
Irrelevant L Z
Open H ?
IC output is tri-state
knowledge:
I don't understand the statement "I am getting values at the Arduino". You should be getting either a LOW or a HIGH the the Arduino pin. Is that what you meant? You should ALWAYS get something, low or high while the encoder is powered.
What are the voltages you are getting from the the encoder output? Are they higher than 0.2 and lower than -0.2?
How is the encoder powered?
Paul
Yes, I am getting continuously HIGH & LOW signals at arduino input. I should get values when motor is rotating but I am getting values when motor is in steady state.
+5v is given to encoder separately. All grounds are common.
Is your project associated with this thread?
http://forum.arduino.cc/index.php?topic=543224.0
Can you please post your code?
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
Can you please post a copy of your complete circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
What is the encoder, make, model, link to data/specs please.
Ops image.
Tom..
knowledge:
How do you know this is not correct? Perhaps the device changes frequency when rotated.
Paul
[ / code]
#include "PinChangeInterrupt.h" // PinChange Interrupt library
signed long pulses; //Output pulses.
int pulsesChanged = 0;
int encoderA = 2;
int encoderB = 3;
int encoderZ = 4;
Serial.flush();
pinMode(encoderA, INPUT);
pinMode(encoderB, INPUT);
pinMode(encoderZ, INPUT);
attachInterrupt(digitalPinToInterrupt(2), A_CHANGE, CHANGE);
attachInterrupt(digitalPinToInterrupt(3), B_CHANGE, CHANGE);
void A_CHANGE() {
if ( digitalRead(encoderB) == 0 ) {
if ( digitalRead(encoderA) == 0 ) {
// A fell, B is low
pulses--; // moving reverse
// A rose, B is low
pulses++; // moving forward
// B fell, A is high
pulses++; // moving reverse
// B rose, A is high
pulses--; // moving forward
pulsesChanged = 1;
data();
void B_CHANGE() {
// B fell, A is low
// B rose, A is low
pulsesChanged = 1;
data1();
void data1() {
if (pulsesChanged != 0) {
pulsesChanged = 0;
int readB = digitalRead(encoderB);
Serial.print("B ");
Serial.println(readB);
Serial.println(pulses);
Serial.flush();
void data() {
pulsesChanged = 0;
int readA = digitalRead(encoderA);
Serial.print("A ");
Serial.println(readA);
Serial.flush();
[code]
Yes, same project.
Please find attachment of schematic.[/code]
Thanks, OPs Circuit;
How long is the cable from the encoder to the 3486?
Tom..
Paul_KD7HB:
Paul
I can see motor is not rotating so I am definitely sure that I am not getting results. And I am not getting one or two changes in output it is continuously changing.
So I am not able to differentiate when motor is actually rotating.
Try this version. If one of the pins is pulsing even when the encoder isn't moving it may be noise in the signal.
volatile long Position = 0; //Output pulses.
volatile boolean PinAChanged = false;
volatile boolean PinBChanged = false;
const unsigned long ReportInterval = 500; // Display position twice per second, if changed.
const byte EncoderAPin = 2;
const byte EncoderBPin = 3;
const byte EncoderZPin = 4;
pinMode(EncoderAPin, INPUT);
pinMode(EncoderBPin, INPUT);
pinMode(EncoderZPin, INPUT);
attachInterrupt(digitalPinToInterrupt(EncoderAPin), A_CHANGE, CHANGE);
attachInterrupt(digitalPinToInterrupt(EncoderBPin), B_CHANGE, CHANGE);
static unsigned long timeOfLastReport;
unsigned long currentTime = millis();
if (currentTime - timeOfLastReport >= ReportInterval) {
timeOfLastReport += ReportInterval;
// Grab volatile data with interrupts off
noInterrupts();
boolean pinA = PinAChanged;
boolean pinB = PinBChanged;
long position = Position;
interrupts();
if (pinA || pinB) { // If either pin changed
if (pinA)
Serial.print("Pin A Interrupted. ");
if (pinB)
Serial.print("Pin B Interrupted.");
Serial.println(position);
void A_CHANGE() {
PinAChanged = true;
boolean stateA = digitalRead(EncoderAPin);
boolean stateB = digitalRead(EncoderBPin);
if (stateA) { // A rose
if (stateB) { // B is HIGH
Position--; // moving reverse
} else { // B is LOW
Position++; // moving forward
} else { // A fell
void B_CHANGE() {
PinBChanged = true;
if (stateB) { // B rose
if (stateA) { // A is HIGH
} else { // A is LOW
} else { // B fell
Since the OP won't tell us if or how the encoder is powered, my guess is: it is not powered and so the pins on the encoder are floating and this is what he is seeing.
Paul
avr_fred:
Are your stepper motors connected with 500 meters of cable as well?
At 500 meters, the cable type chosen will be a critical factor. It must be shielded, twisted pair cable specifically for RS422 use.
Remove the capacitors from the signal lines.
Are the resistors 200 ohms?
Sorry cable length is 500mm & cable is shielded.
Value of resistor is 200ohms
Cables for Stepper motor is of 200mm length
The capacitors must be removed.
The need for the resistors is questionable with short cables and I would testing without them. When required for voltage reflection issues, R should be closer to 100-120 ohms, not 200.
Paul_KD7HB:
Paul
Externally supply is given to encoder which is denoted as +5v in schematic. This is supplied by 5v SMPS and same supply is given to line receiver IC 3486.
knowledge:
Thank you for your code. I have tested circuit with this code. I am getting same results, continuous increment in pulses.
Here is attached results:
Pin A Interrupted. Pin B Interrupted.-479
Pin A Interrupted. Pin B Interrupted.-477
Pin A Interrupted. Pin B Interrupted.-486
Pin A Interrupted. Pin B Interrupted.-496
Pin A Interrupted. Pin B Interrupted.-502
Pin A Interrupted. Pin B Interrupted.-505
Pin A Interrupted. Pin B Interrupted.-507
Pin A Interrupted. Pin B Interrupted.-497
Pin A Interrupted. Pin B Interrupted.-509
Pin A Interrupted. Pin B Interrupted.-504
Pin A Interrupted. Pin B Interrupted.-524
Pin A Interrupted. Pin B Interrupted.-539
Pin A Interrupted. Pin B Interrupted.-547
Pin A Interrupted. Pin B Interrupted.-556
You may have to accept the fact that your device is broken. Did you buy it new or did you find a used device?
Paul
If you are getting this many pin changes when the encoder isn't moving I can only guess that there is some pretty bad noise on the input pins. Put an oscilloscope on those pins to see what is happening. Also put an oscilloscope on the input pins of the IC to see if the differential inputs are behaving properly.
From your previous thread, did you try this connection config?
Can you please post a link to the specs/data of your encoder please?
What is its make and part number?
Tom....
