Differentiate between A3 and D3 in code
This might be a stupid question, but I can't seem to find the answer.
I have a Pro-Mini 16MHz from Sparkfun. I'd like to use all of the pins, but I'm confused about how I would define the use of both the A3 and D3 pins. I know I can't just say pin 3 right?
For example:
I can do analogRead(3) and that's A3 right? Can't I also do digitalRead(3) and that be D3?
I can do analogRead(3) and that’s A3 right? Can’t I also do digitalRead(3) and that be D3?
Yes, that is correct the analogread and digitalread functions know which pin 3 to use, A3 or D3 respectively.
Lefty
OK, that part make sense. But what if I want to use A3 as a digital IO pin?
Then you use the following from the Arduion reference section:
"The analog input pins can be used as digital pins w/ numbers 14 (analog input 0) to 19 (analog input 5). "
so using:
pinMode(17, INPUT); val = digitalRead(17);
Will allow the A3 pin to be used as a digital input pin.
Lefty
Sweetness. Thanks a bunch. What section was that under?
http://arduino.cc/en/Reference/DigitalRead
