Ciao
Sto confrontando alcune board per sensori di temperatura
max 31855
max 6675
per termocoppia tipo K
max 31865
per una PT100
ho messo tutto in uno sketch ma il max 31855 da valori diversi da quelli che ottengo se lo uso singolarmente con l'esempio della libreria
This is an example for the Adafruit Thermocouple Sensor w/MAX31855K
Designed specifically to work with the Adafruit Thermocouple Sensor
----> https://www.adafruit.com/products/269
These displays use SPI to communicate, 3 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <SPI.h>
#include "Adafruit_MAX31855.h"
// Default connection is using software SPI, but comment and uncomment one of
// the two examples below to switch between software SPI and hardware SPI:
// Example creating a thermocouple instance with software SPI on any three
// digital IO pins.
#define MAXDO 6
#define MAXCS 7
#define MAXCLK 8
// initialize the Thermocouple
Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
// Example creating a thermocouple instance with hardware SPI
// on a given CS pin.
//#define MAXCS 10
//Adafruit_MAX31855 thermocouple(MAXCS);
// on SPI1 using specified CS pin.
//#define MAXCS 10
//Adafruit_MAX31855 thermocouple(MAXCS, SPI1);
while (!Serial) delay(1); // wait for Serial on Leonardo/Zero, etc
Serial.println("MAX31855 test");
// wait for MAX chip to stabilize
Serial.print("Initializing sensor...");
if (!thermocouple.begin()) {
Serial.println("ERROR.");
while (1) delay(10);
Serial.println("DONE.");
// basic readout test, just print the current temp
Serial.print("Internal Temp = ");
Serial.println(thermocouple.readInternal());
double c = thermocouple.readCelsius();
if (isnan(c)) {
Serial.println("Something wrong with thermocouple!");
Serial.print("C = ");
Serial.println(c);
//Serial.print("F = ");
//Serial.println(thermocouple.readFahrenheit());
questo รจ l'output
MAX31855 test
Initializing sensor...DONE.
Internal Temp = 25.75
C = 27.75
Internal Temp = 26.87
C = 21.50
Internal Temp = 27.31
C = 22.25
Internal Temp = 27.69
C = 22.50
mentre se uso lo sketch che ho creato inglobando l'esempio della libreria
//2021 04 22
//#include <Adafruit_MAX31865.h> PT100
//in questo sketch vengono utilizzati insieme per verificare le differenze
//#include "max6675.h" termocoppia tipo K
//sensori in parallelo per verificare corrispondenza
//#include "Adafruit_MAX31855.h" termocoppia
//#include "Adafruit_MCP9808.h"
This is a library for the Adafruit PT100/P1000 RTD Sensor w/MAX31865
Designed specifically to work with the Adafruit RTD Sensor
----> https://www.adafruit.com/products/3328
This sensor uses SPI to communicate, 4 pins are required to
interface
// this example is public domain. enjoy!
// https://learn.adafruit.com/thermocouple/
/////////////////////////////////////////////////termocoppia con max 31855
#include <SPI.h>
// digital IO pins.
#define MAXDO 6
#define MAXCS 7
#define MAXCLK 8
Adafruit_MAX31855 thermocouple_1(MAXCLK, MAXCS, MAXDO);
//// Example creating a thermocouple instance with hardware SPI
//// on a given CS pin.
////#define MAXCS 10
////Adafruit_MAX31855 thermocouple_1(MAXCS);
//// on SPI1 using specified CS pin.
////Adafruit_MAX31855 thermocouple_1(MAXCS, SPI1);
/////////////////////////////////////////////////termocoppia con max 6675
#define thermoDO 3
#define thermoCS 4
#define thermoCLK 5
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
//#define MAXDO 6
//#define MAXCS 7
//#define MAXCLK 8
//// initialize the Thermocouple
//MAX6675 thermocouple_1(MAXCLK, MAXCS, MAXDO);
//////////////////////////////////////////////////PT100 con max 31865
#define tCS 10
#define tSI 11
#define tSO 12
#define tCK 13
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31865 thermo = Adafruit_MAX31865(tCS, tSI, tSO, tCK);
//Adafruit_MAX31865::Adafruit_MAX31865(int8_t spi_cs, int8_t spi_mosi, int8_t spi_miso, int8_t spi_clk) {
// use hardware SPI, just pass in the CS pin
//Adafruit_MAX31865 thermo = Adafruit_MAX31865(10);
// The value of the Rref resistor. Use 430.0 for PT100 and 4300.0 for PT1000
#define RREF 430.0
// The 'nominal' 0-degrees-C resistance of the sensor
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL 100.0
////////////////////////////////////////////////////////////////////max 31855
if (!thermocouple_1.begin())
////////////////////////////////////////////////////////////////PT100 con max 31865
Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
thermo.begin(MAX31865_3WIRE); // set to 2WIRE or 4WIRE as necessary
//////////////////////////////////////////////////termocoppia con max 31855
Serial.println("Max31855");
// Serial.print("Internal Temp = ");
// Serial.println(thermocouple_1.readInternal());
double c = thermocouple_1.readCelsius();
if (isnan(c))
Serial.print("Temperature = ");
// Serial.print("C = ");
Serial.println(c);
//Serial.println(thermocouple_1.readFahrenheit());
// digitalWrite(MAXCS, LOW);
/////////////////////////////////////////////PT100 max 31865
Serial.println("Max31865");
uint16_t rtd = thermo.readRTD();
// Serial.print("RTD value: ");
// Serial.println(rtd);
float ratio = rtd;
ratio /= 32768;
// Serial.print("Ratio = ");
// Serial.println(ratio, 8);
// Serial.print("Resistance = ");
// Serial.println(RREF * ratio, 8);
// Serial.println("PT100");
Serial.println(thermo.temperature(RNOMINAL, RREF));
// Check and print any faults
uint8_t fault = thermo.readFault();
if (fault)
Serial.print("Fault 0x"); Serial.println(fault, HEX);
if (fault & MAX31865_FAULT_HIGHTHRESH) {
Serial.println("RTD High Threshold");
if (fault & MAX31865_FAULT_LOWTHRESH) {
Serial.println("RTD Low Threshold");
if (fault & MAX31865_FAULT_REFINLOW) {
Serial.println("REFIN- > 0.85 x Bias");
if (fault & MAX31865_FAULT_REFINHIGH) {
Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_RTDINLOW) {
Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_OVUV) {
Serial.println("Under/Over voltage");
thermo.clearFault();
Serial.println("Max6675");
//Serial.print("C = ");
Serial.println(thermocouple.readCelsius());
// Serial.print("F = ");
// Serial.println(thermocouple.readFahrenheit());
// For the MAX6675 to update, you must delay AT LEAST 250ms between reads!
// // basic readout test, just print the current temp
// Serial.println("Max6675");
// Serial.print("Temperature = ");
// //Serial.print("C = ");
// Serial.println(thermocouple_1.readCelsius());
// // Serial.print("F = ");
// // Serial.println(thermocouple.readFahrenheit());
// // For the MAX6675 to update, you must delay AT LEAST 250ms between reads!
// Serial.println();
// delay(1000);
ottengo questo output
MAX31855 test
Max31855
Temperature = 21.75
Max31865
Temperature = 20.43
Max6675
Temperature = 20.75
Max31855
Temperature = 14.50
Max31865
Temperature = 20.43
Max6675
Temperature = 21.00
Max31855
Temperature = 15.50
Max31865
Temperature = 20.46
Max6675
Temperature = 21.00
Max31855
Temperature = 15.75
Max31865
Temperature = 20.43
Max6675
Temperature = 20.50
Max31855
Temperature = 14.75
avete qualche idea
grazie
stefano
