I put together a simple app to read IR remote pulses with a Uno and an IR receiver. The receiver data line is connected to Pin2. I have an interrupt set for Pin 2 state changes. When the interrupt hits I look at the Pin state and grab the current usec count from micros() to calculate the pulse time. In my loop() I want to check if we’ve gone a while since the last Pin2 state change as this would signal the end of the IR data from the. I grab the current usec count from micros() and compare it to the last usec count grabbed in the interrupt routine. The problem I am having is occasionally the usec count returned from micros() in the loop() function is smaller that the last one received in the interrupt routine. It’s not a wraparound to 0 and I’ve debugged enough with Serial.print() to believe I’m not crazy. I’m getting the same results in 1.0 and 1.5.6-r2.
#include <limits.h>
int LEDPin = 13;
volatile int LEDState = LOW;
enum IRReadState
IR_IDLE = 0,
IR_READING_PULSE,
IR_READING_GAP
typedef struct _IRPulse
// start and end are for debugging only
unsigned long start;
unsigned long end;
unsigned int length;
bool active;
} IRPulse;
volatile enum IRReadState s_currentReadState = IR_IDLE;
volatile enum IRReadState s_lastReadState = IR_IDLE;
volatile unsigned long s_currentPulseStart = 0;
const unsigned int s_sizePulses = 100;
IRPulse s_Pulses[s_sizePulses];
volatile unsigned int s_idxNextPulse = 0;
volatile unsigned int s_printError = 0;
// copied from libraries
extern volatile unsigned long timer0_overflow_count;
unsigned long _micros()
unsigned long m;
uint8_t oldSREG = SREG, t;
cli();
m = timer0_overflow_count;
#if defined(TCNT0)
t = TCNT0;
#elif defined(TCNT0L)
t = TCNT0L;
#else
#error TIMER 0 not defined
#endif
#ifdef TIFR0
if ((TIFR0 & _BV(TOV0)) && (t < 255))
m++;
#else
if ((TIFR & _BV(TOV0)) && (t < 255))
m++;
#endif
SREG = oldSREG;
return ((m << 8) + t) * (64 / clockCyclesPerMicrosecond());
// calculate a time difference taking into account possible wraparound
unsigned int diffTime( unsigned long i_endTime, unsigned long i_startTime )
if( i_startTime > i_endTime )
return (unsigned int) (ULONG_MAX - i_startTime + i_endTime);
return (unsigned int) (i_endTime - i_startTime);
// set up LED for flashing
pinMode( LEDPin, OUTPUT );
// set up an interrupt for IR Receiver on Pin 2
// IR Receiver must be on Pin 2. Uno only supports
// interrupts from Pin 2 & 3
attachInterrupt( 0, Pin2Change, CHANGE );
s_currentPulseStart = _micros();
// set up Serial for spew
Serial.begin( 115200 );
Serial.println( "Ready to record IR signals." );
static unsigned int lastPulseCount = 0;
static unsigned int idxCurrentCommand = 0;
unsigned int currentPulseCount = s_idxNextPulse;
// Print a message that the interrupt is actually doing it's job
if( lastPulseCount != currentPulseCount )
Serial.print( "Pulse Count: " );
Serial.print( currentPulseCount );
Serial.println( "." );
lastPulseCount = currentPulseCount;
// If we've received pulses and are in a gap state we may be done.
// Look for a long gap
if( (idxCurrentCommand < s_idxNextPulse) && (s_currentReadState == IR_READING_GAP) )
unsigned long current = _micros();
unsigned long start = s_currentPulseStart;
unsigned int delay = diffTime( current, start );
if( delay > 32767 )
Serial.print( "I: " );
Serial.print( s_idxNextPulse );
Serial.print( " C: " );
Serial.print( current );
Serial.print( " S: " );
Serial.print( start );
Serial.print( " RS: " );
Serial.print( s_currentReadState );
Serial.print( " LRS: " );
Serial.print( s_Pulses[s_idxNextPulse - 1].active );
if( s_idxNextPulse < s_sizePulses )
s_Pulses[s_idxNextPulse].start = start;
s_Pulses[s_idxNextPulse].end = current;
s_Pulses[s_idxNextPulse].length = 32767;
s_Pulses[s_idxNextPulse].active = false;
s_idxNextPulse++;
unsigned int commandEndPulse = s_idxNextPulse;
Serial.flush();
// Print out the pulses in this command
for( unsigned int i = idxCurrentCommand; i < commandEndPulse; i++ )
Serial.print( "Pulse[" );
Serial.print( i );
if( s_Pulses[i].active )
Serial.print( "]: On " );
Serial.print( "]: Off " );
Serial.print( s_Pulses[i].length );
Serial.print( " usec." );
Serial.print( " E: " );
Serial.print( s_Pulses[i].end );
Serial.print( s_Pulses[i].start );
Serial.flush();
idxCurrentCommand = commandEndPulse;
if( s_printError > 0 )
Serial.print( "State change error: " );
Serial.print( s_printError );
s_printError = 0;
// Our interrupt that detects state changes
void Pin2Change()
const bool signalReceived = !(PIND & _BV(2));
switch( s_currentReadState )
case IR_IDLE:
if( signalReceived )
s_currentReadState = IR_READING_PULSE;
s_printError = 1;
case IR_READING_PULSE:
if( !signalReceived )
s_Pulses[s_idxNextPulse].start = s_currentPulseStart;
s_Pulses[s_idxNextPulse].end = _micros();
s_Pulses[s_idxNextPulse].length = _micros() - s_currentPulseStart;
s_Pulses[s_idxNextPulse].active = true;
s_idxNextPulse++;
s_currentReadState = IR_READING_GAP;
s_printError = 2;
case IR_READING_GAP:
s_idxNextPulse++;
s_printError = 3;
Thanks,
Joe
