Difficulté programmation capteur DHT22
Bonjour,
Je me tourne vers vous car je tente actuellement de réaliser mon premier mini-projet Arduino : une petit centrale météo, toute bête pour le moment, avec un capteur DHT22. Seulement, c’est ce dernier qui me pose problème, en effet, lors de la compilation, le message suivant s’affiche :
In file included from C:\Users\**** *****\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:22:0:
C:\Users\**** *****\Documents\Arduino\libraries\DHT-sensor-library-master\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
 #include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
Mon programme, issue de dossier ressource de Adafruit:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 2     // what digital pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
  Serial.println("DHTxx test!");
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
En attente de vos lumière
bonjour,
message clair pourtant
mais je ne sais pas où tu as chopé la lib, surement sur github de adafruit
Étant donné mon faible niveau d'anglais, et mon absence de connaissance informatique, que dois-je faire exactement? Car j'ai déjà retenter en installant se dossier via la bibliothèque du logiciel Arduino, mais il y a toujours cette erreur qui subsiste :frowning:
je t'ai donné le lien pour télécharger la lib manquante
tu la mets dans le répertoire libraries et tu relance l'ide
Géniale, merci.
Nouveau problème. Aprés essaie grace au moniteur, j'ai pus constater que l'humidité restait bloqué à 1%. Je me suis donc penché sur le code, et j'ai constaté que cette ligne :
Restait noire, contrairement à celle de la température, qui est bien orange. J'en conclue donc que c'est ma commande qui n'est pas reconnue, mais je ne sais par quoi la remplacer. Avez-vous des idées?
Bonjour,
Si ta fonction n'était pas reconnue, tu aurais une erreur de compilation.
On peut aussi conclure à un défaut dans le fichier keywords associé à la bibliothèque.
Tu n'es pas dans l'univers professionnel où tu payes cher des bibliothèques en béton.
Il faut accepter de garder son esprit critique en éveil permanent.
La bibliothèque Adafruit n'est pas la meilleure.
Il en existe une sur le playground arduino écrite par des bénévoles et de bien meilleure qualité
http://playground.arduino.cc/Main/DHTLib
Avec celle ci tu n'aura pas d'erreur CheckSum.
