I just bought a GPS shield based on ublox neo-6m chip.
I also use the Elegoo Mega2560 as a controller.
I have read alot of forum posts on the subject but none of them had the specific hardware that I have. There are 2 jumpers on the shield which I can use to link to digital pins 0 through 7 for TX and RX.
I have tried every pin setup imaginable and still get no data. I also tried to remove the jumpers and use dupont jumper wires connected to pin 18 and 19 (RX and TX on the Mega).
Using the TinyGPS++ library with the FullExample.ino I only get output full of *** on all columns.
FullExample.ino
An extensive example of many interesting TinyGPS++ features
Testing TinyGPS++ library v. 1.0.2
by Mikal Hart
Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum
(deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail
**** ***** ********** *********** **** ********** ******** **** ****** ****** ***** *** ******** ****** *** 0 0 0
No GPS data received: check wiring
I noticed on some posts that people got time but all other columns where full of ***. Like this :
FullExample.ino
Testing TinyGPS++ library v. 0.92
by Mikal Hart
**** **** ********** *********** **** 00/00/2000 00:00:00 71 ****** ****** ***** *** ******** ****** *** 159 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 182 ****** ****** ***** *** ******** ****** *** 321 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 259 ****** ****** ***** *** ******** ****** *** 483 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 336 ****** ****** ***** *** ******** ****** *** 645 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 412 ****** ****** ***** *** ******** ****** *** 807 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 489 ****** ****** ***** *** ******** ****** *** 969 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 565 ****** ****** ***** *** ******** ****** *** 1131 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 642 ****** ****** ***** *** ******** ****** *** 1293 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 720 ****** ****** ***** *** ******** ****** *** 1455 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 796 ****** ****** ***** *** ******** ****** *** 1617 0 1
0 9999 ********** *********** **** 00/00/2000 00:00:00 873 ****** ****** ***** *** ******** ****** *** 1779 0 1
I understand that obtaining the time but no other columns means there is no connexion to any satellites. I know I have to get outside on a clear sky in order to connect to any satellite. All I want for now is to be able to wire the thing properly. Using the shield I believe I should not have to wire anything, am I right?
