Difficulty creating a function from a varriable
Hi- I am very new to programming, and am stuck. I need to read the state of a button press, and if it's held longer than 500ms, I would like to turn an LED on. If it's < 500ms, the loop should continue. I"m frustrated because this seems like it should be easy, but my code isn't working:
//GSwitch timer test
const int ledPin = 11;
const int startPin = 10;
long startTime;
unsigned long duration;
  pinMode(13,OUTPUT);
  digitalWrite(13,LOW);
  pinMode(startPin, INPUT);
  digitalWrite(startPin, HIGH);
  pinMode(ledPin, OUTPUT);
  if(digitalRead(startPin) == LOW)
     // here if the switch is pressed
     startTime = millis();
     while(digitalRead(startPin) == LOW)
        ; // wait while the switch is still pressed
    duration = millis() - startTime;
     if(duration >= 500);
       digitalWrite (ledPin,HIGH);
     Serial.println(duration);
When I watch in the serial monitor, I can see the button presses registering and reasonable times are being reported out, but within half a second of resetting, my LED pin goes high (#11), regardless of button activity.
What's that semicolon doing there?
