Difficulty displaying an image from IP cam on Arduino R4 Wi-Fi web server
Hello everyone, I own an Arduino R4 Wi-Fi and a USB camera 'converted' into an IP cam using a program called Yawcam. By typing the IP address (all local) of the PC to which the USB camera is connected into a browser, I can see what the camera is pointing at. My goal is to display an image from the 'IP cam' on the Arduino R4 web server (I wanted to start with something simple and then move on to real-time video streaming), but instead of the image, an icon with the text I wrote in the alt attribute is shown. Does anyone know how to help?
The code is as follows:
#include "WiFiS3.h"
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                 // your network key index number (needed only for WEP)
int led =  12;
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  Serial.begin(9600);      // initialize serial communication
  pinMode(led, OUTPUT);      // set the LED pin mode
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to Network named: ");
    Serial.println(ssid);                   // print the network name (SSID);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
  server.begin();                           // start the web server on port 80
  printWifiStatus();                        // you're connected now, so print out the status
  WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("new client");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out to the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println();
            client.print("<html>");
            client.print("<head>");
            client.print("<style>");
            client.print(".button {");
            client.print("  background-color: #FF0000;");
            //client.print("  border-color: #000000;");
            client.print("  color: black;");
            client.print("  padding: 50px;");
            client.print("  text-align: center;");
            client.print("  text-decoration: none;");
            client.print("  display: inline-block;");
            client.print("  font-size: 16px;");
            client.print("  margin: 4px 60px;");
            client.print("  cursor: pointer;");
            client.print("}");
            client.print(".button5 {border-radius: 50%;}");
            client.print("</style>");
            client.print("</head>");
            client.print("<body>");
            client.print("<a href=\"/H\"><button class=\"button button5\"></button></a>");
            client.print("<img src=' my ip' alt='IP Camera Stream'>");
            client.print("<p style=\"font-size:7vw;\">Click <a href=\"/L\">here</a> turn the LED off<br></p>");
            client.print("</body>");
            client.print("</html>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          } else {    // if you got a newline, then clear currentLine:
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /H")) {
          digitalWrite(13, HIGH);               // GET /H turns the LED on
        if (currentLine.endsWith("GET /L")) {
          digitalWrite(13, LOW);                // GET /L turns the LED off
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
Is there an easier way to do all of this?
If it turns out that what I want to do is possible, how could I implement real-time video streaming?
p.s. I translated the message with a translator, so if something is unclear, I can try to explain it again.
This is what I use for an ESP32 cam
<iframe src="http://192.168.1.5/" id="iframe1" width=400 height="290"  style=" position: absolute; top: 0px;right: 0%;border:none; overflow: hidden"></iframe>
It works, thanks a lot
Why did you start two topics with the same subject?
Thanks, second thread (cross-posting) closed.
Guglielmo
