Difficulty switching between automatic and manual modes
This project is meant to be a fan with two modes. An automatic mode controls the speed of the fan based on readings from a temperature sensor, and a manual mode which changes the speed based on user input from buttons.
One button controls switching between auto/manual and the respective LEDs that represent each. The other button is used to switch between the speeds of manual mode.
The code worked well when it was seperated, but since putting it together it does not seem to work as intended, even though the respective circuits are identical.
The buttons seem to either change states on their own or when connected via jumper wire rather than when clicked
Would this be more of a code issue or a circuit issue?
Any help would be appreciated.
Here is my code:
//***AUTO/MANUAL SWITCH***//
int modeSwitchPin = 2;              // switch is connected to pin 2
int ledAutoPin = 10;
int ledManPin = 11;
int val;                        // variable for reading the pin status
int val2;                       // variable for reading the delayed status
int modeButtonState;                // variable to hold the button state
int Mode = 0;
//***AUTO SPEED CONTROL***//
#include <dht.h>
#define dht_dpin 12
dht DHT;
#define motorControl 9
//***MANUAL SPEED CONTROL
int switchPin = 3;              // switch is connected to pin 3
int ledLowPin = 6;
int ledMedPin = 7;
int ledHighPin = 8;
int motorPin = 9;
int val3;                        // variable for reading the pin status
int val4;                       // variable for reading the delayed status
int manSpeedButtonState;                // variable to hold the button state
int State = 0;
  //***AUTO/MANUAL SWITCH SETUP***//
  pinMode(modeSwitchPin, INPUT);    // Set the switch pin as input
  pinMode(ledAutoPin, OUTPUT);
  pinMode(ledManPin, OUTPUT);
  modeButtonState = digitalRead(modeSwitchPin);   // read the initial state
  //***MANUAL SPEED CONTROL SETUP***//
  pinMode(switchPin, INPUT);
  pinMode(ledLowPin, OUTPUT);
  pinMode(ledMedPin, OUTPUT);
  pinMode(ledHighPin, OUTPUT);
  pinMode(motorPin, OUTPUT);
  manSpeedButtonState = digitalRead(switchPin);   // read the initial state
  //***AUTO SPEED CONTROL SETUP***//
  pinMode(motorControl, OUTPUT);
  analogWrite(motorControl, 255);
  //***AUTO/MANUAL SWITCH LOOP***//
  val = digitalRead(modeSwitchPin);      // read input value and store it in val
  delay(10);                         // 10 milliseconds is a good amount of time
  val2 = digitalRead(modeSwitchPin);     // read the input again to check for bounces
  if (val == val2) {                 // make sure we got 2 consistant readings!
    if (val != modeButtonState) {          // the button state has changed!
      if (val == LOW) {                // check if the button is pressed
        if (Mode == 0) {
          Mode = 1;
          if (Mode == 1) {
            Mode = 0;
  modeButtonState = val;                 // save the new state in our variable
  if (Mode == 0)  //***FAN IS IN AUTOMATIC MODE***//
    digitalWrite(ledAutoPin, HIGH);
    digitalWrite(ledManPin, LOW);
    Serial.println("Automatic Mode");
    digitalWrite(ledLowPin, LOW);
    digitalWrite(ledMedPin, LOW);
    digitalWrite(ledHighPin, LOW);
    //***AUTO SPEED CONTROL LOOP***//
    DHT.read11(dht_dpin);
    int temp = DHT.temperature;
    Serial.print("Temperature = ");
    Serial.println(DHT.temperature);
    if (temp >= 29)
      digitalWrite(motorControl, 255);
      Serial.println("Fan Speed: 100%");
      delay(10);
    else if (temp == 28)
      digitalWrite(motorControl, 204);
      Serial.println("Fan Speed: 80%");
      delay(10);
    else if (temp == 27)
      digitalWrite(motorControl, 153);
      Serial.println("Fan Speed: 60%");
      delay(10);
    else if (temp == 26)
      digitalWrite(motorControl, 102);
      Serial.println("Fan Speed: 40%");
      delay(10);
    else if (temp <= 25)
      digitalWrite(motorControl, 51);
      Serial.println("Fan Speed: 20%");
      delay(10);
  if (Mode == 1)  //***FAN IS IN MANUAL MODE***//
    digitalWrite(ledAutoPin, LOW);
    digitalWrite(ledManPin, HIGH);
    Serial.println("MANUAL MODE");
    //***MANUAL SPEED LOOP***//
    val3 = digitalRead(switchPin);      // read input value and store it in val
    val4 = digitalRead(switchPin);     // read the input again to check for bounces
    if (val3 == val4)
      if (val3 != manSpeedButtonState)
        if (val3 == LOW)
          if (State == 0)
            State = 1;
          else if (State == 1)
            State = 2;
          else if (State == 2)
            State = 3;
          else if (State == 3)
            State = 0;
    manSpeedButtonState = val3;                 // save the new state in our variable
    // Now do whatever the lightMode indicates
    if (State == 0) { // all-off
      digitalWrite(motorPin, 0);
      Serial.println("Fan Off");
    if (State == 1) {
      digitalWrite(ledLowPin, HIGH);
      digitalWrite(motorPin, 85);
      Serial.println("Low Speed");
    if (State == 2)
      digitalWrite(ledMedPin, HIGH);
      digitalWrite(motorPin, 170);
      Serial.println("Medium Speed");
    if (State == 3)
      digitalWrite(ledHighPin, HIGH);
      digitalWrite(motorPin, 255);
      Serial.println("High Speed");
How are the switches wired? If you've set them to INPUT you will need external pull-up resistors to Vcc.
Thank you so much! I don't know why I had forgot to implement that into my circuit. It works as intended now!
