Rather simple project in definition, but over my head in coding.
I am trying to trigger three digital outputs based on a switch (simple enough) and a scale reading on one of our mixer trucks. When the scale reads 3000 i want one output to come on for an engine set speed. when it reaches 10,000 i want the other output to go high to trigger a different engine speed. The truck interface is digital inputs, so rather straight forward. However I can't figure out how to read the serial data from our scales. I got help from digistar to get my scale set to the proper 9600 baud and output.
Here is the information in the tech manual from Digi-Star. Any help would be appreciated.
5. RS-232 Specifications
5.1 Signal Levels
The Printer, Computer, and Scoreboard are capable of communicating using the EIA
Registered Standard #232 (RS-232). The signal levels move between +8 and -8 Volts.
The Scoreboard also has another communication port that drives 20 milli-Amp devices.
5.2 Communication Parameters
Data is transmitted and received in the asynchronous ASCII format. This communication
format is compatible with most printers, computers, and terminals. The Alternate Port
Configuration is used when the Scoreboard Mode (SCOREM) is set to 4.
Standard Port Configuration
1200 BAUD
1 Start Bit
7 Data Bits
1 EVEN Parity Bit
1 Stop Bit
Alternate Port Configuration
9600 BAUD
1 Start Bit
7 Data Bits
1 EVEN Parity Bit
1 Stop Bit
“Handshake lines” are not used and XON/XOFF is not supported.
These parameters are not adjustable in the scale. Equipment interfacing to the scale
must match this configuration.
