Digispark Attiny85 İnstall
Hello, I want to upload the existing code to digispark. I would love it if you could help with this. Thanks in advance.
what code? I see no code.
Do you have support installed for your attiny85?
https://create.arduino.cc/projecthub/alaspuresujay/use-an-attiny85-with-arduino-ide-07740c
  • Automatic Stair light controller
  • Detects motion via a PIR (pin 2 digital) and gradually turns on an LED Light strip (pin 3 digital).
  • When motion ceases the LED light strip is gradually turned off.
  • An LDR (Analog A0) is used to detect ambient light levels. The LED is only turned on if the ambient
  • light level is lower than a specified threshold.
  • Change history
  • 2020-10 GMc 1.01.02.00
  • Added startup feedback showing the number of PIRs configured in the program.
  • 2020-10 GMc 1.01.01.00
  • Added print of PIR configuration and Version.
  • 2020-10 GMc 1.01.00.00
  • Added Debug constant+debug messages
  • Expanded the PIR checking to support multiple PIR's
  • Added version history block
  • 2016-04 GMc 1.00.00.00
  • Initial Version
#define VERSION "1.01.02.00"
// Uncomment the following for debug messages.
//#define DEBUG
// Define a constant that determines at what light level should
// should the LED strip be turned on. If the light level is above
// this threshold, the LED strip will not be turned on when motion is triggered.
#ifdef DEBUG
#define LIGHT_ON_THRESHOLD 700
#else
#define LIGHT_ON_THRESHOLD 200
#endif
// The pins to which the various peripherals are connected.
// NB: The pirPins array defines the pins to which the PIR signal (or out) pins are connected to.
// IMPORTANT: The contents of this array need to be modified to reflect the number of PIR's that you have.
// each entry in the pirPins array defines that a PIR is connected to the specified pin.
// below are three examples that show 1 to 3 PIRs connected to the Arduino.
const int pirPins [] = {2}; // Define a single PIR connected to DIO pin 2
//const int pirPins [] = {2, 4}; // Define dual PIRs. One is connected to DIO pin 2, the other to DIO pin 4.
//const int pirPins [] = {2, 4, 5}; // Define triple PIRs. They are connected to DIO pins 2, 4 and 5.
const int pirCount = sizeof(pirPins) / sizeof(pirPins[0]); // The number of PIR's defined.
const int ledStripPin = 3; // Output: PWM signal to the MOSFET.
const int lightSensorPin = A0; // Input: The reading from the ligh sensor (LDR)
// Cooperative multi-tasking data.
// Cooperative multi-tasking works by activating a task from time to time.
// The period of time between activations depends upon the task.
// This variables is used to track the point in time that we last checked the
// Arduino clock. Our main loop will continually check to see if the Arduino's clock
// has ticked over (> 1ms has passed since we last did anything). If it has, then
// the individual tasks are checked to see if it is time that they should be activated.
// You can visually see this working if you activate the Serial monitor in the Arduino IDE.
// What you will see is that the ambient light level reporting will seemingly randomly appear
// in amongst any other debugging messages you might add to the program (e.g. outputting the
// brightness level during a fade).
unsigned long timePrev = 0;
// Multi-tasking sub tasks:
// - Read the PIR once every 10 ms.
// - If turning on the LED's, adjust the brightness ever 10 ms
// - It turning off the LED's, adjust the brightness every 30 ms
// - Report the light leveel once every second (this is primarily for testing).
#define PIR_TIME 10 // Check the PIR every 10 ms
unsigned int pirReadTmr = 0; // A counter to measure how long since we last checked the PIR
#define FADE_ON_TIME 10 // LED's "fade on", the brightness is increased every 10 ms.
#define FADE_OFF_TIME 30 // LED's "fade off", the brightness is decreased every 30 ms.
unsigned int faderTime = FADE_ON_TIME; // will be set to either FADE_ON_TIME or FADE_OFF_TIME depending upon
// whether we are turning the LED's on or off.
unsigned int faderDelayTmr = 0; // A counter to measure how long since we last adjusted the LED brightness.
#define LIGHT_CHECK_TIME 1000 // Check the ambient light level once every 1000 ms (once per second)
unsigned int lightCheckTmr = 0; // A counter to measure how long since we last reported the ambient light level.
  • Setup:
    • Initialise the Serial comm's just in case we are debugging/testing.
    • set up the MOSFET (ledStripPin) and builtin LED PIN to output
    • Initialise the multi-tasking timer (timePrev),
int cnt = 0;
// Wait for the the Serial port to initialise (but don't wait forever)
while (!Serial && cnt < 100) {
cnt++;
delay(10);
// Set the digital outputs (LED_BUILTIN and LED Strip MOSFET)
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
pinMode(ledStripPin, OUTPUT);
digitalWrite(ledStripPin, LOW);
#ifdef DEBUG
Serial.println(F("Debug mode on"));
#endif
Serial.print(F("Stairlight - "));
Serial.println(VERSION);
Serial.print(pirCount); Serial.print(F(" PIR configured on pin(s): "));
for (int i = 0; i < pirCount; i++) {
if (i != 0) {
Serial.print(F(", "));
Serial.print(pirPins[i]);
// Blink the led strip and builtin once for each PIR configured as
// visual feedback during startup.
analogWrite(ledStripPin, 128);
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
analogWrite(ledStripPin, 0);
delay(100);
// Initialise the time Keeper
timePrev = millis();
  • Loop:
    • Check to see if the time has changed.
    • If the time has changed, work out how long has elapsed since the last
  • time we checked (should always be 1 ms)
    • Update the 3 sub-task time counters.
    • Check each sub-task time counter to see if it has passed it's respective
  • threshold.
  • - If we have passed the threshold, call the appropriate sub-task.
  • - reset the appropriate time counter to 0.
// Get the current time in millis.
// Note that the value is unsigned long. If you do not use unsigned long, then
// after a few days your multi-tasking might "freak out" (the technical term for
// not performing as expected).
unsigned long timeNow = millis();
// Has the time progressed since last time we checked?
if (timeNow != timePrev) {
// Yep, so work out how long has passed (normally 1 ms)
unsigned int delta = timeNow - timePrev;
// Capture the current time so we can check if time has moved on from "right now".
timePrev = timeNow;
// Update the sub-task time counters.
pirReadTmr += delta;
faderDelayTmr += delta;
lightCheckTmr += delta;
// Has the pir timer passed it's threshold? If so, check the PIR.
if (pirReadTmr >= PIR_TIME) {
  processPir();
  pirReadTmr = 0;
// Has the fader timer passed it's threshold? If so, adjust the brightness of the LED's
if (faderDelayTmr >= faderTime) {
  processFade();
  faderDelayTmr = 0;
// Has the ambient light level timer passed it's threshold? If so, report the ambient light level.
if (lightCheckTmr >= LIGHT_CHECK_TIME) {
  processLightCheck();
  lightCheckTmr = 0;
  • check PIR Array
  • Check each of the PIRs for motion detection.
  • If any of them report motion detected, return a HIGH value (motion detected).
  • Otherwise if none of them have reported any motion detected (i.e. all of them are LOW), then return a LOW value.
    int checkPirArray() {
    // Step through the array of PIRs one by one
    int triggeredInd = digitalRead(pirPins[i]); // Read the PIR
    if (triggeredInd) { // Is it triggered (i.e. triggeredInd is HIGH)?
    #ifdef DEBUG
    Serial.print("pir "); Serial.print(i); Serial.print(F(" (DIO pin ")); Serial.print(pirPins[i]); Serial.println(F(") triggered."));
    #endif
    return HIGH; // Yes, it is triggered, we only need one, so return immediately with a "motion detected" status.
    return LOW; // None of the PIRs are triggered, so return a no motion detected status.
  • Multi-tasking sub tasks start here
    // Variable to track the last known state of the PIRs - initially this should be OFF.
    int pirState = LOW;
// Variables to track what the LED control is doing.
bool fadeDisabled = true; // Are we fading? true = NO, false = YES
bool fadeUp = true; // Which direction are we fading? true = ON (i.e. getting brighter), false = OFF (i.e. getting dimmer)
int brightness = 0; // The current brightness. Initially the LED's are off, therefore the brightness is 0.
  • Process PIR
    • Called when it is time to check the PIR to see if it has changed state.
    • If the PIR has changed state, initiate the appropriate action for the LED.
  • Note. It is possible that the PIR will report that "motion has stopped". This might happen
  • part way through the LED turning off cycle. If this occurs, then the fadeOFf will immediately be
  • stopped and the fadeOn will be initiated.
  • This could happen if someone moves out of sight of the PIR, but returns shortly after the PIR
  • stops reporting motion.
  • The overall result is the that the LED's will smoothly transition from whatever brightness level
  • they happened to be at back to full brightness with no ugly blinking, flashing or sudden jump to
  • an extreme level of brightness.
  • While the above scenario can be handled without multi-tasking, it is much easier (IMHO) to do with
  • this form of multi-tasking. That is checking the PIR state changes while simultaneously adjusting the
  • LED brightness (and as it happens, simultaneously reporting the ambient brightness once every second).
    void processPir() {
    // Read the PIR and see if it's state has changed from last time we checked.
    int pirTriggeredInd = checkPirArray(); // Call the function that checks the PIR array for motion.
    if (pirTriggeredInd != pirState) { // has the motion status changed since we last checked?
    pirState = pirTriggeredInd; // Yes, PIR state has changed, so record this new state for subsequent state change checking.
    if (pirState == HIGH) { // Has the PIR detected motion?
    Serial.println("Motion Detected"); // Yep!
    // Signal that motion has been detected by turning the BUILTIN_LED on.
    // Determine if we need to turn on the LED Strip.
    // we will turn on the LED strip if:
    // a) the ambient light level is less than the LIGHT_ON_THRESHOLD, or
    // b) the current state of the LED's is on (brightness > 0)
    if (getLightLevel() < LIGHT_ON_THRESHOLD || brightness > 0) {
    fadeOn(); // initiate the turn LED's on sub-task
    } else { // Motion no longer detected.
    Serial.println("Motion ended");
    // Signal that motion is no longer detected by turning the BUILTIN_LED off.
    fadeOff(); // initiate the turn LED's off sub-task
  • Fade On
  • Initiates the turning ON of the LED strip.
    void fadeOn() {
    fadeDisabled = false; // Enable the fader sub-task.
    fadeUp = true; // Set the direction to "turn on LED's" (i.e. "get brighter").
    faderTime = FADE_ON_TIME; // Set the timer threshold that controls how frequently we increase the brightness.
  • Fade Off
  • Initiates the turning OFF of the LED strip.
    void fadeOff() {
    fadeUp = false; // Set the direction to "turn off LED's" (i.e. "get dimmer").
    faderTime = FADE_OFF_TIME; // Set the timer threshold that controls how frequently we decrease the brightness.
  • Fader sub-task
  • Adjusts the brightness of the LED strip.
  • Note that the brightness of the LED's is written to the LED strip PIN using analogWrite.
  • This means that the Arduino uses PWM to rapidly switch the LED's on and off during the period of time
  • between calls to this sub-task (either 10 or 30 ms). The proportion of time that the LED's are ON compared
  • to the time that they are off is directly related to the value written to the port (i.e. the value in brightness).
  • A value of 0 means the LED's are ON for 0% of the time and OFF 100% of the time (i.e. totally off).
  • A value of 63 or 64 means roughly 25% of the time ON and 75% of the time off (i.e. one quarter brightness).
  • A value of 127 means roughly 50% of the time ON and 50% of the time OFF (i.e. half brightness).
  • A value of 255 means 100% of the time ON and 0% of the time OFF (i.e. full brightness).
  • Each time this sub-task is called, it will increase (or decrease) the brightness by 1 if the sub-task is enabled.
    void processFade() {
    // First, check to see if the sub-task is active?
    if (fadeDisabled) {
    return; // No, just return (i.e. do nothing).
// Debug: Output the current brightness level every 32 steps and when it reaches the maximum.
// if ((brightness & 0x1F) == 0 || brightness == 255) {
// Serial.print(" ** brightness = ");
// Serial.println(brightness);
// The sub-task is active (i.e. we are "fading" the LED's)
if (fadeUp) { // Are we increasing the brightness?
if (brightness < 255) { // Yep, is the current brightness less than the maximum possible value?
brightness++; // Yep, increase the brightness and write it to the ledStripPin
analogWrite(ledStripPin, brightness);
fadeDisabled = true; // We have reached the maximum brightness (=255) so this task is done. Disable it.
// Serial.println("Fade on done.");
} else { // We are decreasing the brightness (turning the LED's off)
if (brightness > 0) { // Is the current brightness more than the minimum possible value?
brightness--; // Yep, decrease the brightness by 1 and write it to the ledStripPin.
analogWrite (ledStripPin, brightness);
fadeDisabled = true; // We have reached the minimum brightness (= 0) so this task is done. Disable it.
// Serial.println("Fade off done.");
  • get Light Level
  • Check and return the ambient light level in a range from 0 (darkest) to 1023 (brightese)
    int getLightLevel() {
    // Calculate the light level as the inverse of the value read.
    // The circuit (LDR connected to ground and resistor connected to +5V) means that as it get's darker, the
    // LDR resistance get's higher. Therefore the reading at A0 gets closer to +5V which is read as higher values at A0.
    // Similarly as it get's brighter, the LDR's resistance get's closer to zero, therefore the voltage at A0 gets lower,
    // which is read as lower values at A0.
    // This is, IMHO, counter intuitive, so the easy solution is to subtract the A0 reading from 1023 which means
    // brighter ambient light (low reading) gives a higher result (e.g. 1023 - 0 = 1023)
    // darker ambient light (high reading) gives lower result (e.g. 1023 - 1023 = 0)
    int lightLevel = 1023 - analogRead(lightSensorPin); // Photo resistor with 10K voltage divider
    return lightLevel;
  • process Light check
  • sub task that periodically reports the current ambient light level.
    void processLightCheck() {
    int lightLevel = getLightLevel();
    Serial.print("Light level: ");
    Serial.println(lightLevel);
Please take a few minutes to read this: How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
and then edit your post and put all that code inside code tags so the code does not get messed up.
I can send you an e-mail if you want.
 * Automatic Stair light controller
 * Detects motion via a PIR (pin 2 digital) and gradually turns on an LED Light strip (pin 3 digital).
 * When motion ceases the LED light strip is gradually turned off.
 * An LDR (Analog A0) is used to detect ambient light levels. The LED is only turned on if the ambient
 * light level is lower than a specified threshold.
 * Change history
 * 2020-10 GMc    Added Debug constant+debug messages
 *                Expanded the PIR checking to support multiple PIR's
 * 2016-04 GMc    Initial Version
//#define DEBUG
#ifdef DEBUG
#else
#endif
 * Setup:
 * - Initialise the Serial comm's just in case we are debugging/testing.
 * - set up the MOSFET (ledStripPin) and builtin LED PIN to output
 * - Initialise the multi-tasking timer (timePrev),
  int cnt = 0;
      cnt++;
      delay(10);
#ifdef DEBUG
#endif
  Serial.println(F("Ready"));
 * Loop:
 * - Check to see if the time has changed.
 *   - If the time has changed, work out how long has elapsed since the last
 *     time we checked (should always be 1 ms)
 *   - Update the 3 sub-task time counters.
 *   - Check each sub-task time counter to see if it has passed it's respective
 *     threshold.
 *     - If we have passed the threshold, call the appropriate sub-task.
 *     - reset the appropriate time counter to 0.
    timePrev = timeNow;
      processPir();
      pirReadTmr = 0;
      processFade();
      faderDelayTmr = 0;
      lightCheckTmr = 0;
 * check PIR Array
 * Check each of the PIRs for motion detection.
 * If any of them report motion detected, return a HIGH value (motion detected).
 * Otherwise if none of them have reported any motion detected (i.e. all of them are LOW), then return a LOW value.
#ifdef DEBUG
#endif
 * Multi-tasking sub tasks start here
int pirState = LOW;
 * Process PIR
 * - Called when it is time to check the PIR to see if it has changed state.
 * - If the PIR has changed state, initiate the appropriate action for the LED.
 * Note. It is possible that the PIR will report that "motion has stopped". This might happen
 * part way through the LED turning off cycle. If this occurs, then the fadeOFf will immediately be
 * stopped and the fadeOn will be initiated.
 * This could happen if someone moves out of sight of the PIR, but returns shortly after the PIR
 * stops reporting motion.
 * The overall result is the that the LED's will smoothly transition from whatever brightness level
 * they happened to be at back to full brightness with no ugly blinking, flashing or sudden jump to
 * an extreme level of brightness.
 * While the above scenario can be handled without multi-tasking, it is much easier (IMHO) to do with
 * this form of multi-tasking. That is checking the PIR state changes while simultaneously adjusting the
 * LED brightness (and as it happens, simultaneously reporting the ambient brightness once every second).
void processPir() {
 * Fade On
 *   Initiates the turning ON of the LED strip.
void fadeOn() {
 * Fade Off
 *   Initiates the turning OFF of the LED strip.
void fadeOff() {
 * Fader sub-task
 *   Adjusts the brightness of the LED strip.
 *   Note that the brightness of the LED's is written to the LED strip PIN using analogWrite.
 *   This means that the Arduino uses PWM to rapidly switch the LED's on and off during the period of time
 *   between calls to this sub-task (either 10 or 30 ms). The proportion of time that the LED's are ON compared
 *   to the time that they are off is directly related to the value written to the port (i.e. the value in brightness).
 *   A value of 0 means the LED's are ON for 0% of the time and OFF 100% of the time (i.e. totally off).
 *   A value of 63 or 64 means roughly 25% of the time ON and 75% of the time off (i.e. one quarter brightness).
 *   A value of 127 means roughly 50% of the time ON and 50% of the time OFF (i.e. half brightness).
 *   A value of 255 means 100% of the time ON and 0% of the time OFF (i.e. full brightness).
 *   Each time this sub-task is called, it will increase (or decrease) the brightness by 1 if the sub-task is enabled.
  if (fadeDisabled) {
 * get Light Level
 *  Check and return the ambient light level in a range from 0 (darkest) to 1023 (brightese)
  return lightLevel;
 * process Light check
 *  sub task that periodically reports the current ambient light level.
Okay, that's the code. What is the issue? Does it compile? or upload? Are there errors? What are those errors?
I want to run this code or a similar code in digispark. I can do it with Arduino mini pro. But I can't compile for digispark. I would really appreciate if you can help.
If you want people to help, then you have to provide some yourself. Did you answer the questions in #8? I think not. Please provide the errors you are receiving. Do not expect others to have your exact setup to test things out for you.
