Digispark ATTINY85 out of storage. How to tidy up?
Hey guys,
I'm having a difficult time trying to reduce the used space of my sketch. I'm lacking 300bytes of storage space.
Any ideas?
//#include <DigisparkOLED.h>
#include <TinyWireM.h>
#include <Tiny4kOLED.h>
//#include <Wire.h>
#include <EnableInterrupt.h>
#include <EEPROMex.h>
volatile int CurrentTime;
volatile int hallPin = 3;
volatile int modus;
volatile int StartTime;
volatile double velocity [10];
volatile float staytime;
volatile float staystart;
volatile double reifenumfang = 2330; //in mm
volatile double maxvelocity;
volatile double mileage;
volatile double deltamileage;
volatile double cache;
volatile boolean iszero=false;
volatile float timeelapsed;
#define INTERRUPTEDPIN 1 // == B1
const uint8_t inputBitMask = digital_pin_to_bit_mask_PGM[INTERRUPTEDPIN];
volatile uint8_t interruptState=0;
void messure(){
  CurrentTime = millis();
  if(iszero){
    staytime+=double(millis()-staystart);
  iszero=false;
  if (digitalRead(hallPin)== LOW && CurrentTime-StartTime>0){
    timeelapsed= (CurrentTime-StartTime);
    StartTime = millis();
    cache = (reifenumfang/timeelapsed)*3.6;
    if(cache<100){
      if(cache>maxvelocity){                                      //Updaten der Topspeed und Mileage
        maxvelocity=cache;
      mileage+=reifenumfang/1000000;
      deltamileage+=reifenumfang/1000000;
      for (int i=9;i>0;i--){                                           //Überschreiben der Werte
        velocity[i]=velocity[i-1];
      velocity[0]=cache;
  DDRB &= ~inputBitMask; // INPUTPIN is set to input
  PORTB |= inputBitMask; // Pull up the resistor
  MCUCR &= ~PUD; // ensure Pull Up Disable is off
  enableInterrupt(INTERRUPTEDPIN, messure, FALLING);
  //Serial.begin(9600);
  if(isnan(EEPROM.readDouble(0))){
      EEPROM.writeDouble(0,0);
  if(isnan(EEPROM.readDouble(10))){
      EEPROM.writeDouble(10,0);
  pinMode(2, INPUT);
  pinMode(hallPin, INPUT);
  //attachInterrupt(1,messure,FALLING);
  oled.begin();
  if((CurrentTime-StartTime>5000)&&(!iszero)){
    iszero=true;
    staystart=millis();
  if(digitalRead(2)==HIGH){
    modus++;
    modus=modus%2;
   oled.clear(); //all black
  displayupdate();
  cache=EEPROM.readDouble(10);
  if(cache<maxvelocity){
    EEPROM.writeDouble(10,maxvelocity);
  if(deltamileage>0.7){
    cache=EEPROM.readDouble(0)+deltamileage;
    deltamileage=0;
    EEPROM.writeDouble(0,cache);
void displayupdate(){
  oled.setCursor(0, 0);
  oled.setFont(FONT8X16);
  oled.print(velocity[0]);
Why you use 'float' type for time variables? This is completely pointless, slow down the program and uses a lot of memory - the variables themselves and the library to work with them. Replace them all with 'unsigned long' and try again.
As an aside , it’s not a great idea to routinely read and write to eprom , it will wear out - you only need to put anything there you want at next switch on .
