I have multiple Digisparks and nrf24l01 and I want to be able to communicate between them.
But after some research and trying out some methouds I'm not sure if this is possible.
Since the Digispark only has a limited amount of pins. Does anyone know if its possible to have two or multiple Digisparks communicate with each other using nrf24l01?
Thanks in advanced!
The strict answer to your question is probably, yes, but you may not have any pins left over on the Digispark to use as inputs or outputs
What sort of data are you aiming to transmit and receive ?
