Digital clock with RTC and serial 7 segment display
So I’ve got myself an uno, a DS3231 RTC and a serial 7 segment display and i’m trying to get the display to show the current time. Bear in mind that i’m a complete coding novice.
I’ve connected the display TX>8 and RX>7 and i’ve bodged/copied the below code but i’m getting the error message ‘rtc’ was not declared in this scope on the “s7s.print(String(rtc.hour())); // Print hour” line.
  1. Is this code way more complicated than I need?
  2. If it’s what I need whats the problem with that line?
#include <DS3231.h>
#include <SoftwareSerial.h>
#define DS3231_CS_PIN A5 // RTC Chip-select pin
const int softwareTx = 8; //serial pin assignment for 7SD
const int softwareRx = 7;
unsigned long previousTime = 0;
const long interval = 1000;
boolean colon = false;
SoftwareSerial s7s(softwareRx, softwareTx);
  Serial.begin(9600); // Baud for serial monitor communication
  s7s.begin(9600); // Baud for 7 segment communication
  clearDisplay(); // Clear the display before jumping into loop
  setBrightness(255); // max brightness
  rtc.begin(DS3231_CS_PIN);
  //rtc.autoTime(); // Pulls an initial time from IDE's time, comment out once time is set
  static int8_t lastSecond = -1;
  static int8_t lastMinute = -1;
  static int8_t lastHour = -1;
  // Call rtc.update() to update all rtc.seconds(), rtc.minutes(),
  // etc. return functions.
  rtc.update();
  if (rtc.second() != lastSecond) // If the second has changed
    printTime(); // Print the new time
    lastSecond = rtc.second(); // Update lastSecond value
  if (rtc.minute() != lastMinute) // If the minute has changed
    lastMinute = rtc.minute(); // Update lastMinute value
  if (rtc.hour() != lastHour) // If the hour has changed
    lastHour = rtc.hour(); // Update lastHour value
   colonBlink();
}  // end loop
//////////FUNCTIONS///////////
void printTime()
  if (rtc.hour() < 10)
    s7s.print('0'); // Print leading '0' for hour
  if (rtc.minute() < 10)
    s7s.print('0'); // Print leading '0' for minute
  s7s.print(String(rtc.minute())); // Print minute
/*Uncomment to see time on serial monitor
    Serial.print(String(rtc.hour()) + ":"); // Print hour
    Serial.print('0'); // Print leading '0' for minute
  Serial.print(String(rtc.minute()) + ":"); // Print minute
  if (rtc.second() < 10)
    Serial.print('0'); // Print leading '0' for second
  Serial.print(String(rtc.second())); // Print second
  Serial.println();*/
void clearDisplay()
  s7s.write(0x76);  // Clear display command
void setDecimals(byte decimals)
  s7s.write(0x77);
  s7s.write(decimals);
void setBrightness(byte value)  //Brightness of S7D
  s7s.write(0x7A);  // Set brightness command byte
  s7s.write(value);  // brightness data byte
void colonBlink()
  unsigned long currentTime = millis();
  if( currentTime - previousTime >= interval)
    previousTime = currentTime;
    if(colon == false)
      colon = true;
      setDecimals(0b00010000);
      colon = false;
      setDecimals(0b00000000);
Can you post links to the DS3231 library your using as there are several versions out there but none I have seen need a Chip Select signal (DS3231_CS_PIN).
The error your getting is probably because the library is not installed correctly or your not using it correctly in your code.
You don't have a global (outside of setup/loop) definition for rtc so this might be a problem.
The below code is not really needed as the seconds changed code will do all you need (you don't change minutes or hours without changing seconds first)
colonBlink() is more complex than needed but that's just a cosmetic thing so no important yet.
Don't i2c device libraries also need Wire.h?
rtc is an object that you have to initialize.
I use this:
DS3231  rtc(SDA, SCL);
I’m using an arduino mega but I’d imagine that you could set SDA and SCL to A0 and A1.
