I need the connections for this project and code such as the project starts with button and the motor turns 180 when object is available asap
When you have decided what parts you will be using, look for example code on the web.
I believe the title is incomplete
“…scan a 180”
A 180 what? You should to quote the full requirement they gave you
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
In 180 degrees range and rhe buzzer beeps when an object is obstructing the measuring process
Now there is a buzzer.
What is the full requirement?
I need help in connecting the componenets i tried ln tinkercad the simulation worked but when i connect irl it doesnt work
Digital Distance Meter displays the result on an LCD screen, which can show different measurement units (meter, centimeter, millimeter) and scan a 180° range by using Ultrasonic Sensors with Servo Mechanism. It also has a buzzer for alerts if an object is too close and simulation starts with a button.
This is what is required i
What components?
For instructions on what to do to get help from this forum, please read the "How to get the best out of this forum" post, linked at the head of every forum category.
