I would like to log 9 bytes of data from a MC at a known interval, the data is collected from dataout pin 18 on a AMICCOM A7201A chip and is connected to Arduino Digital Input. (GND to GND also ).
The 9 bytes (including checksum) start after a long LOW period of 500ms and a HIGH period of 500us then 72 bits at 200us intervals are read and stored.
The data will then be then passed to WRT54GL Router with modified serial port onto the internet for pachube to graph with my other data.
Data is sent every 6 seconds to the RX module. the header part of the transmition is ignored.
I have been following this link
http://electrohome.pbworks.com/w/page/34379858/Efergy-Elite-Wireless-Meter-Hack#comment1306967574
for the project the guy Alex has the same efergy E2 unit as me and made it work in PIC but has no Arduino experience .
Hence my questions are :-
- Do I need to activate pull up resistor on digital pin to make it work ?
- How do I debug such a program given speed of 200us ?
- Is my logic correct to concatenate bits into bytes ?
- Is pulseIn() the right function to use to wait for the right intervals ?
My code so far (untested)
int E2Pin = 8; // Digital Input Pin allocated to E2 output
int E2Bytes = 8; // actual bytes of data required
int pulseDUR = 200; // pulse duration of data in usecs
int leadHIGH = 500; // lead HIGH duration in usecs
long longLOW = 500000;// long LOW duration in usecs before leadHIGH
boolean DataINflg = LOW;// flag to determine when to collect DataINflgflg
boolean pauseLOWflg = LOW;// flag to determine of pauseLOWflg period has occured
int E2pulse; // pulse of data reived from E2
byte byte_array[9]; // array of bytes read
//pulseIn() used here to our benefit
//Reads a pulse (either HIGH or LOW) on a pin. For example, if value is HIGH, pulseIn() waits for the pin to go HIGH,
//starts timing, then waits for the pin to go LOW and stops timing. Returns the length of the pulse in microseconds.
//Gives up and returns 0 if no pulse starts within a specified time out.
//The timing of this function has been determined empirically and will probably show errors in longer pulses.
//Works on pulses from 10 microseconds to 3 minutes in length.
//Syntax
//pulseIn(pin, value)
//pulseIn(pin, value, timeout)
// main loop starts here
Serial.print("SETUP > ");
pinMode(13, OUTPUT); // init LED to show progress
pinMode(E2Pin,INPUT);
DataINflg = LOW;
pauseLOWflg = LOW;
E2pulse = digitalRead(E2Pin); // get à value on E2 Digital Pin
digitalWrite(13,E2pulse);
if (E2pulse == HIGH) {
if ( pulseIn(E2Pin, HIGH) >= leadHIGH) { // see if we have reached start of data
if (pauseLOWflg == HIGH) { // only set ready to accept reading data if pauseLOWflg has passed
DataINflg = HIGH;
Serial.print("READY DATA > ");
} // else ignore and go round again
else { // pulse is LOW check if short or long
if ( pulseIn(E2Pin, LOW) >= longLOW) { // skip the long low period
pauseLOWflg = HIGH;
Serial.print("PAUSE LOW >");
if ( DataINflg == HIGH ) { // time to collect the get the data we want
get_next_nbytes( E2Bytes+1, pulseDUR);
// send data here if we want
for (int Byte = 1 ; Byte <= 9 ; Byte++){
Serial.print(byte_array[Byte],BYTE);
Serial.print(" :");
DataINflg = LOW; // reset vars
pauseLOWflg = LOW;
} // end of loop
// function to read next nbytes at Cycle microsecond intervals last byte checksum
void get_next_nbytes(int Nbytes,int Cycle)
int CheckSum = 0;
int bitval;
int Nbits = 8;
delayMicroseconds(Cycle/2); // delay a 1/2 cycle to be bang in middle of pulse
for (int Byte = 1 ; Byte <= Nbytes ; Byte++) {// for each byte to be read
for (int Bit = 1 ; Bit <= Nbits ; Bit++) { // for each bit within the byte
bitval = digitalRead(E2Pin); // read databit from digital pin
if (bitval == HIGH) {
byte_array[Byte] |= (1 << Bit); // bitshift data into this byte
else {
byte_array[Byte] &= ~(1 << Bit); // bitshift data into this byte
delayMicroseconds(Cycle) ; // delay to land in the middle of each bit
CheckSum += byte_array[Byte]; // keep track of data received
if (CheckSum != byte_array[Nbytes]){ // bad checksum
Any Help/Guidance welcome.
Kind Regards
Jean
