Digital-logger plduino wifi
Hi, I just bought a Digital Logger Open Source PLC. I am completely new to Arduino. I would like to use it to control my pool equipment and use an embedded web server. I have the example code up and running with the web server, but I cannot figure out how to change the ssid, password and IP address. I tried some other ESP8266 example code, but I get wifi sheld not present or some other error probably telling me it is not a compatible board. Can anyone help point me in the right direction? thanks Bent
Can anyone even see the code you are talking about? Besides you, that is.
This is the example they have on their website: https://github.com/digitalloggers/PLDuino It works fine, but the web server in this example has hardcoded ssid, password and ip address. I couldn't find anywhere to change it.
I can’t guess where you went from the “link” you provided to get the example that you started from. The icon with the chain links and green circle is obviously (to some demented moron) the icon to use to post a link. Post a link to the page that shows the example that you started from.
You probably found a solution by now, but here's my method that I just discovered today:
https://forum.arduino.cc/index.php?topic=494313.0
