Hy AWOL,
I tried to use the example adding some codes to read a temp and humidity but no way!!! where am i wrong? thanks again for your precious help!
Andrea.
This is the code:
#include <SHT1x.h>
#define dataPin 22 // DATA
#define clockPin 24 // SCK
SHT1x sht1x(dataPin, clockPin); // temp and humidity sensor
// constants won't change. Used here to
// set pin numbers:
const int ledPin = 2; // the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 100; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
Serial.println("Starting up");
Serial.print("Temperature: ");
Serial.println("F. Humidity: ");
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
float temp_c;
float humidity;
temp_c = sht1x.readTemperatureC();
humidity = sht1x.readHumidity();
Serial.print(temp_c);
Serial.print(" ");
Serial.print(",");
Serial.print(humidity);
Serial.print(" ");
Serial.println(",");
delay(100);
