digital output is always high
Hi, I’m a noob with programming and I wan’t to learn to understand it a little bit. Thats why I recently bought a arduino to control the lights on the stairs
To control the light I also bought a ldr and a weight sensor.
in text:
If I put my foot on the weight sensor and it’s dark, the relay is high.
Else the relay is low.
I tested a lot and it was working with 1 sensor but not with 2.
This is my code.
const int m = A1; // pressure sensor
const int x = A2; // ldr
const int r = 3; // relay
const int ldrw = 200;
const int psen = 800;
  pinMode(r, OUTPUT);
  pinMode(x, INPUT); // ldr
  pinMode(m, INPUT); // pressure sensor
  while (! Serial); //
  Serial.println(A1);
  // read sensors
  Serial.println(analogRead(m)); // pressure sensor
  Serial.println(analogRead(x)); // ldr
  delay (500);
  int  y = analogRead(m); //pressure sensor
  int  z = analogRead(x); //ldr
  if (y > psen && z < ldrw);
    digitalWrite (r, HIGH);
  if (y < psen && z > ldrw);
    digitalWrite (r, LOW);
I uploaded the code to my arduino and he set the relay alway high. When I open the serial monitor I see 2 value’s
  • apr. 2 for the pressuresensor
  • apr. 700 for the ldr.
I hope you can help me.
Thanx!
Smagedy
  if (y > psen && z < ldrw);oops
AWOL:
Maybe it’s obvious but I don’t understand what you mean :-[
In all the examples you've seen, you never seen a line like that, that ends like that.
  Serial.begin(250000);
  if (6 == 9);
    Serial.println(F("six is nine"));
void loop() {}
Somewhere\TrailingSemi\TrailingSemi.ino:3:14: warning: suggest braces around empty body in an 'if' statement [-Wempty-body]
   if (6 == 9);
six is nine
Tanks for the reply's (sorry for the late response) but it is working now. AWOL tanks I was blind.
