Digital Pin of PIR sensor reads high while radio transmits
In my project I have a DHT temperature/humidity sensor and a PIR. I'm transmitting the data those two sensors receive to another device. When I transmit the data with the "radio.sendWithRetry" the pin connected to the PIR goes "high" or reads 3.3 volts and triggers a false positive movement of the sensor. I've tried moving my PIR sensor to different pins but each time I notice the same thing. I'm using the miniWirelessHW-915 (Anarduino MiniWireless Details) for this project. Below is my code. Please help and thank you in advance.
#include <dht.h>
//Start RFM69 Specific Code -------------------------------------------------------------------------------------------------
#include <RFM69.h>
#include <SPI.h>
#define NODEID        10    //unique for each node on same network 1X=basement 2X=Main Level
#define NETWORKID     14  //the same on all nodes that talk to each other
#define GATEWAYID     1
#define FREQUENCY     RF69_915MHZ
#define ENCRYPTKEY    "WIRELESSKEY" //exactly the same 16 characters/bytes on all nodes!
#define IS_RFM69HW    //uncomment only for RFM69HW! Leave out if you have RFM69W!
#define ACK_TIME      30 // max # of ms to wait for an ack
#define LED           9  // Moteinos have LEDs on D9
#define SERIAL_BAUD   115200  //must be 9600 for GPS, use whatever if no GPS
//Device IDs- 2=PIR 3=Magnet 4=Temp/hum 5=IR Sensor 6=Light Sensor
typedef struct {
  int           nodeID;         //node ID
  int           deviceID;       //sensor ID (2, 3, 4, 5, 6)
  unsigned long var1_usl;       //uptime in ms
  float         var2_float;     //sensor data?
  float         var3_float;     //battery condition?
} Payload;
Payload theData;
char buff[20];
byte sendSize=0;
boolean requestACK = false;
RFM69 radio;
// End RFM69 Specific Code -------------------------------------------------------------------------------------------------
int PIRinputPIN = 7;
int pirState = LOW;
int val = 0;
dht DHT;
#define DHT22_PIN 6
  Serial.begin(SERIAL_BAUD);
  Serial.println("Serial Started");
  theData.nodeID = NODEID;
  radio.initialize(FREQUENCY,NODEID,NETWORKID);
  radio.setHighPower();
  radio.encrypt(ENCRYPTKEY);
  char buff[50];
  sprintf(buff, "\nTransmitting at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
  Serial.println(buff);
  pinMode(PIRinputPIN, INPUT);
  theData.nodeID = 10;
  delay(10000); //PIR needs to calibrate
  //deviceID = 2 for PIR
  val=digitalRead(PIRinputPIN);
  if (val == HIGH && pirState == LOW)
      Serial.println("MOTION DETECTED!!!!");
      theData.deviceID = 2;
      theData.var2_float = val;
      radio.sendWithRetry(GATEWAYID, (const void*)(&theData), sizeof(theData));
      pirState = HIGH;
  else if (val == LOW && pirState == HIGH)
    Serial.println("No more motion");
    pirState = LOW;
   delay (10000);
  //deviceID = 4 for temp/humidity
  Serial.println("DHT.read");
  DHT.read22(DHT22_PIN);
  delay(2000);
  Serial.println("DHT.humidity");
  float h = DHT.humidity;
  delay(2000);
  float t = DHT.temperature;
  Serial.println("DHT.temperature");
  delay(2000);
  t = t * 1.8 + 32;
  Serial.print("Temp/Hum: ");Serial.print(t); Serial.print("F / "); Serial.print(h); Serial.print("%");Serial.println(" ");
  delay(2000);
  theData.deviceID = 4;
  theData.var2_float = t;
  theData.var3_float = h;
  delay (2000);
