Digital pin set to INPUT oscillates
I have the following code.
Regardless of whether I apply 5V or GND to pin 35, digitalRead(…) oscillates between 0 and 1 with each iteration of loop()
What am I doing wrong?
CODE
int nLEDPin = 13, nPhotoTransistorPin = 35, nMaxPin = 53;
*digitalPinToPCMSK(A0) |= bit(digitalPinToPCMSKbit(A0)); // Enable pin
PCIFR |= bit(digitalPinToPCICRbit(A0)); // Clear any outstanding interrupt
PCICR |= bit(digitalPinToPCICRbit(A0)); // Enable interrupt for the group
for (int nI = 0; nI < nMaxPin; nI++)
if (nI == nPhotoTransistorPin)
pinMode(nI, INPUT);
pinMode(nI, OUTPUT);
digitalWrite(nI, LOW);
ISR (PCINT0_vect) // handle pin change interrupt for D8 to D13 here
digitalWrite(nLEDPin, digitalRead(A0));
Serial.print("Pin “);
Serial.print(nI);
Serial.print(” = ");
Serial.println(digitalRead(nI));
Serial.print(nPhotoTransistorPin);
Serial.println(digitalRead(nPhotoTransistorPin));
SERIAL MONITOR
Pin 35 = 1
Pin 35 = 1
Pin 35 = 0
Pin 35 = 0
Pin 35 = 0
Pin 35 = 0
Pin 35 = 0
Pin 35 = 0
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 0
Pin 35 = 0
Pin 35 = 0
Pin 35 = 0
Pin 35 = 0
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 1
Pin 35 = 0
Please use pin names rather than number as we then know what it does.
D1 means more than pin? as pin? numbers change with model.
Weedpharma
I found what the problem was.
The expansion board I made was not pushed into the arduino properly so some of its pins were not making contact with the corresponding arduino pins.
But I am still struggling to get the arduino digital pin to detect the phototransistor is tuned on.
I seem to get constant 1 from digital pin 35 or constant 0.
I am using L-51P3C.
Can anyone point me in the direction of a tutorial of using these devices with an arduino digital pin.
I was able to get this device to turn a LED on an off on my bread board:
But this doesn’t seem to work with the arduino digital pin if I just replace the LED anode with the digital pin.
Nor does it seem to work if I connect the phototransistor emitter to the digital pin and a 10k resistor from 5V to the phototransistor emitter.
Phototransistor L-51P3C.pdf (72.8 KB)
Why do,you have two transistors in series?
Try wiring it with 10k from Vcc to digital input pin, then the transistor C to the input and E to gnd.
The program should expect to read a HIGH normally and LOW when the IR is shone onto it. Then use the Arduino to turn on the LED.
Weedpharma
