I have a strange problem in that pins 9 and 10 seem to be electrically connected.
I am testing continuity without any shields attached.
I'm using the megamoto shield from Robot Power, with pins 9 and 10 as my PWM pins.
The symptom is that my scope is showing pins 9 and 10 with identical outputs, thereby locking the motor to VCC. Probing all of the other pins, I don't have any continuity. None of my other Arduinos are showing continuity on pins 9, 10. This is very strange. A visual inspection of the board is not showing anything bridged, but at the same time, is suspect that these two pins on this function are affected.
Is anyone aware of an electrical situation that will electrically connect digital pin 9 and 10 inside the Mega2650? this is a brand new board, the first time I've powered it up.
