I am trying to use a digital potentiometer for volume control with my Arduino Uno.
I am using the LM386 amplifier with the above setup. The mechanical 10K pot has been replaced with a 10K AD5245 Digital pot.
Here is how the pot is wired up:
A = Pin for of Arduino Uno
B = GND
W = Pin 3 of the Amplifier
SDA = A4
SCL = A5
AD0 = GND
Vdd = 5V (Arduino)
GND = GND
I tested out a simple program to check the adjustments of volume and here is the code:
tone(4, 261); //Output tone on pin 4 and 261Hz
Wire.beginTransmission(44); // transmit to device #44 (0x2c)
Wire.write(byte(0x00)); // sends instruction byte
Wire.write(val); // sends potentiometer value byte
Wire.endTransmission(); // stop transmitting
val++; // increment value
if(val == 255)
val = 0; // start over from lowest value
It increases resistance until the value 255 is reached. After testing the code out, the 4th or 5th value is equal to max volume. When using a mechanical linear pot, the volume can be adjust in the first half a turn before reaching maximum volume. Am I doing anything wrong here? Any advice much appreciated!
