Digital Potentiometer with SPI, Daisy Chain
Hi everyone
I'm having problems connecting 3 digital Potentiometers with the Arduino UNO. I'm using the AD5290 from Analog Devices in a daisy chain configuration (see the data sheet)
https://www.analog.com/media/en/technical-documentation/data-sheets/AD5290.pdf
This is a one channel digi pot. I only want to raise the value of all three potentiometers to the maximum or minimum, to see if they work. Here is my code:
#include <SPI.h>
const int slaveSelectPin = 10;
  // set the slaveSelectPin as an output:
  pinMode(slaveSelectPin, OUTPUT);
  // initialize SPI:
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV4);
  digitalWrite(slaveSelectPin, LOW);
  //delay(100);
  SPI.transfer(255); // Data for the last Pot in the daisy chain
  SPI.transfer(255);
  SPI.transfer(255); // Data for the first pot in the daisy chain
  delay(100);
  digitalWrite(slaveSelectPin, HIGH);
All three are in mid position and don't change at all!
Is the code correct? I only need to send the date three time for all pots in the daisy chain. They are all single channel, so I don't need to send a command byte, right?
What else could be wrong?
Thanks for your help
Remove the delay() from the code.
Set the clock divider to DIV8 (working at the maximum frequency is not a good idea).
Post a wiring diagram of your setup!
