Digital PWM RGB LED Problem
As a human being, we have a lot of problems. Sometimes it's a little frustrating, and it's actually a great thing being in a situation that you are forced to solve a problem because what's the point if you have no problem at all, and sometimes the problem is literally unsolvable. Here is the time.
It all started out with this simple, nice and fast PWM single led drive that I have wrote long times ago. It worked fine as it.
// This part is a 4 steps PWM
pwmCounter++;
if(pwmCounter>4) pwmCounter=0;
if(pwmCounter<pwmValue) PORTD |= (1<<7);
else PORTD &= (~1<<7);
if(PWM==5) PWM=0;
if(PWM==255) PWM=4;
pwmValue=PWM;
The problem suddenly appeared once I tried it using color led. the colorful led lighted up right for the brightness part, but the color is a mess. It seems all random instead of predefined white, blue, red, green and etc.
int ta,tb;
uint8_t ledColor; // 0xE0=white; 0x80=BLUE; 0x40=RED; 0x20=Green; 0xC0=Pink; 0x60=Yellow, 0xA0=teal
uint8_t color[]= {0xE0, 0x80, 0x40, 0x20, 0xC0,0x60, 0xA0};
uint8_t cc=0;
byte pwmCounter, pwmValue=4, PWM=3; // 4=off; 0=on; 1=25%; 2=50%; 3=75%;
DDRD=0b11100000;
DDRB&=0;
// This part is a 4 steps PWM state
pwmCounter++;
if(pwmCounter<pwmValue) PORTD = PORTD | (color[cc]);
else PORTD = PORTD & (~color[cc]);
if(PWM==5) PWM=0;
if(PWM==255) PWM=4;
pwmValue=PWM;
ta=millis();
if(ta-tb>1000){
  cc++;
  if (cc>=7) cc=0;
  tb=ta;
Connections:
D5-6-7 >> Output:3 Channels 30V 5.6A MOSfet (Active LOW)
5-6-7 are connected to the RGB led.
I assume that you have tested the individual colours and these work.
Then I guess the clue is here:
To dim the leds you are attempting to "reverse out" the current colour:
which will leave something which does not correspond to one of your seven colours.
I'd try instead :
else PORTD = 0 ;
PORTD &= (~1<<7);
This should be
PORTD &= ~(1<<7);
