Trying to create pulses using switches, but when the switch is pressed it throws an error that the port is not connected. The read is not happening and hence the pulse could not be generated.
The code used is mentioned below
// https://www.arduino.cc/en/Tutorial/BuiltInExamples/Button
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
Serial.begin('9600');
pinMode(13, INPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
Serial.print("Hello");
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
// turn LED off:
digitalWrite(ledPin, LOW);
