Digital read pin 50
Hello, I am trying to figure out how to digital read on pin 50 of my mega2560.
I have a digital moisture sensor on pin 50 and I want to read the state high or low and print it to serial.
digitalRead()
Serial.println()
here is what I have but its not working.
int waterSensor1 = 50;
    digitalRead(waterSensor1);
    Serial.println(waterSensor1);
    delay(10000);
everone:
This code reads the pin, but then does nothing with the reading.
everone:
This code prints the value of the waterSensor1 variable, which you have set to 50 here:
everone:
You don't currently understand how digitalRead works. Please take some time to study the digitalRead() documentation:
and this tutorial:
https://www.arduino.cc/en/Tutorial/DigitalReadSerial
When you read the value with digitalRead, it might be a good idea to store it somewhere so you can use that stored value to output it to the serial. Have a look at variables.
Hello now im having issue with the readings. I only get a 0 reading and am not getting a change.
int sensorValue = digitalRead(50);
     pinMode(50, INPUT);
    digitalRead(sensorValue);
    Serial.println("Water sensor");
    Serial.println(sensorValue);
    delay(10000);
It's much the same problem as before. This code:
everone:
Reads the pin, but you don't do anything with the reading so it's just discarded. Please go back to the documentation and tutorial I recommended in my last reply and really take some time to study it this time.
pert:
It's much the same problem as before. This code:Reads the pin, but you don't do anything with the reading so it's just discarded. Please go back to the documentation and tutorial I recommended in my last reply and really take some time to study it this time.
I am obviously having difficulty with your suggestion. can you point me in the right direction? I keep looking at the direction you previously pointed me to and don't see where I am going wrong.!
There are thousands of tutorials that will teach you how to use digitalRead(), including several built right into the Arduino IDE under File>Examples, but since you are struggling so mightily, try this:
    int x = digitalRead(50);
    Serial.print("Water sensor: ");
    Serial.println(x);
