Hello All.
I am trying to test some Fast Execution Commands in type of pinMode, digitalWrite …
But i have a problem with “Verify”. Program announces mistakes when i use above commands.
So for using that commands, Do i have to import any library or do anything ?
An example code below use these commands, please help me check this code to fix it.
Thanks All!
PS Sorry my bad English
sketch_nov28b.ino (517 Bytes)
hi robtillaart,
I am using Arduino2560.
And here is the code. Please, help me!
// initialize the digital pin as an output.
(DDRH |= _BV (5)); // pinMode (8, OUTPUT);
//(DDRH &= ~_BV (4));
// the loop routine runs over and over again forever:
PORTH |= _BV (5); // digitalWrite (8, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
PORTH &= ~_BV (5); // digitalWrite (8, LOW); // turn the LED off by making the voltage LOW
But i have a problem with "Verify". Program announces mistakes when i use above commands.
What are the error messages?
would be helpful to post them exactly as they appear too.
what board have you selected in the tools menu?
Thanks so much for your help!
I found my mistake by choosing wrong board.
Thank you again
and Best Wish for you!
