I an working on this adding a readout to a microscope X & Y stage. It does have stepper motors but I am not utilizing them, just using it manually. I am connected to the 1000 pulse encoders, one on each axis. I started with a base program from online and have built it up from there. I started with the Y axis and have it working the way I want. I am now trying to incorporate the X axis into the program and keep getting hung up on how to code it to work. I tried coping the "Y" code and change the need variables but it returns with "aiO not in the scope" when it gets to the "X" counter section near the end. I have been working on it all weekend and just can't get it. I have become confused from all the examples and this I have read about the interrupt commands. I always try to figure things out myself but I have thrown the towel in to hopefully get some guidance.
Thank you in advance!!!!
Tom
Here is a 30sec. Youtube video showing the project to hopefully better understand what I am doing:
#include <LiquidCrystal.h>
LiquidCrystal lcd(1, 2, 4, 5, 6, 7);
volatile long tempX, counterX = 0; //This variable will increase or decrease depending on the rotation of encoder
volatile long tempY, counterY = 0; //This variable will increase or decrease depending on the rotation of encoder
int buttonxPin = 13; //used to ZERO out X axis
int buttonyPin = 12; //used to ZERO out Y axis
int buttonxRead;
int buttonyRead;
float counterX;
float counterY;
pinMode(buttonxPin, INPUT_PULLUP); //X axis ZEROing pin
pinMode(buttonyPin, INPUT_PULLUP); //Y axis ZEROing pin
//THE PROBLEMS ARISE FROM BELOW HERE AND I'M NOT SURE OF THE CORRECT CODING
//Setting up interrupt for Y axis
//Y axis- A rising pulse from encodenren activated ai0(). AttachInterrupt 0 is DigitalPin int2(pin 21).
attachInterrupt(2, ai0, RISING);
//Y axis_ B rising pulse from encodenren activated ai1(). AttachInterrupt 1 is DigitalPin int3(pin 20).
attachInterrupt(3, ai1, RISING);
//Setting up interrupt for X axis
//X axis- A rising pulse from encodenren activated ai0(). AttachInterrupt 0 is DigitalPin int4(pin 19).
attachInterrupt(4, ai0, RISING);
//X axis_ B rising pulse from encodenren activated ai1(). AttachInterrupt 1 is DigitalPin int5(pin 18).
attachInterrupt(5, ai1, RISING);
//THE PROBLEMS ARISE FROM ABOVE HERE AND I'M NOT SURE OF THE CORRECT CODING
lcd.begin(16, 2);
//X axis cursor set and ZEROing readout for X
lcd.setCursor(0, 0);
lcd.print("X 0.0000 ");
lcd.setCursor(10, 0);
lcd.print("000.00");
//Y axis cursor set and ZEROing readout for Y
lcd.setCursor(0, 1);
lcd.print("Y 0.0000 ");
lcd.setCursor(10, 1);
// Y axis start
//if "Y Zero" button pushed (int buttonyPin = 12), counterY=0, display "0.000
buttonyRead = digitalRead(buttonyPin);
if (buttonyRead == 0) {
lcd.setCursor(2, 1);
lcd.print ("0.0000 ");
counterY = 0;
delay(10);
//if "X Zero" button pushed (int buttonxPin = 13), counterY=0, display "0.000
buttonxRead = digitalRead(buttonxPin);
if (buttonxRead == 0) {
counterX = 0;
delay(10);
// Send the value of counterY
lcd.setCursor(1, 1);
if ( counterY != tempY ) {
if (0 < (counterY * .001 * .03937))
lcd.print(" ");
lcd.print (counterY * .001 * .03937, 4); //convert counterY pulses to inches, 1000 per revolution
lcd.print (counterY * .001, 3); //convert counterY pulses to milimeters, 1000 per revolution
lcd.print(" ");
else {
lcd.setCursor(9, 1);
lcd.print(" ");
tempY = counterY;
// Y axis end
// X axis start
// Send the value of counterX
if ( counterX != tempX ) {
if (0 < (counterX * .001 * .03937))
lcd.print(" ");
lcd.print (counterX * .001 * .03937, 4); //convert counterY pulses to inches, 1000 per revolution
lcd.print (counterX * .001, 3); //convert counterY pulses to milimeters, 1000 per revolution
lcd.print(" ");
else {
lcd.print(" ");
tempX = counterX;
// counter for Y axis
void ai0() {
// ai0 is activated if DigitalPin nr 2 is going from LOW to HIGH
// Check pin 3 to determine the direction
if (digitalRead(20) == LOW) {
counterY++;
counterY--;
void ai1() {
// ai0 is activated if DigitalPin nr 3 is going from LOW to HIGH
// Check with pin 2 to determine the direction
if (digitalRead(21) == LOW) {
counterY--;
counterY++;
//I GET AN ERROR BELOW HERE, "ai0 not in the scope"
// counter for X axis
void ai0() {
if (digitalRead(18) == LOW) {
counterX++;
counterX--;
void ai1() {
if (digitalRead(19) == LOW) {
counterX--;
counterX++;
// x axis end
