Digital Stop watch_problem with NRF24L01 and external power
Hi Guys,
I´m totally new here and this is my first post.
I´m trying to create a digital stop watch with a IR-Light Barrier and wireless communication.
I´m using two micro´s and two "e18-d50nk" for communication two "NRF24L01".
The distance between the two IR-Sensors is ca. 30m.
I wired up every thing correct and the code works.
When the first Sensors Starts the Stopwatch runs and shows me on the LCD. When the second sensor is pulled down a char[] "S" will be send and the reciever stops with the stopwatch.
MY PROBLEM NOW:
When one arduino is powered with the USB, so when it´s connected with the Serial the Reciever can communiced with transmitter.
But when I power the two arduinos with a external power supply unit, the stop watch begins to count when i hit the first sensor, but it doesent recieve any data from the transmitter.
I installed a Piezo to hear it, when the transmitter is sendig data, or the reciever is getting data, the transmitter is sendig data, with external power, but the reciever doesn´t take it.
I can´t find the problem, why does the arduino nothing recieve, when it´s powered by a external power supply.
I also tried to start first the transmitter, and then the reciever and reversed, but it doesn´t help anything.
HAS ANYONE EXPERIENCE WITH THIS?
THANK`S A LOT :smiley:
Here the Code:
TRANSMITTER:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8);
const byte rxAddr[6] = "00001";
//FOR BEEPER
int Speaker = 2;
//FOR SENSOR
int Input_Sensor = 12;
char test[] = "S";
//SETUP
//Serial.begin(9600);
radio.begin();
radio.setRetries(15, 15);
radio.openWritingPipe(rxAddr);
radio.stopListening();
pinMode(Input_Sensor, INPUT);
pinMode(Speaker, OUTPUT);
//DEFINE FUNCTIONS
void BEEP(int frequency);
//LOOP
if(digitalRead(Input_Sensor) == HIGH)
radio.write(&test, sizeof(test));
BEEP(200);
//PEEP FUNCTION FOR SPEAKER
// generate a 1KHz tone for 1/2 second
for (int i = 0; i < 500; i++)
digitalWrite(Speaker, HIGH);
delayMicroseconds(frequency);
digitalWrite(Speaker, LOW);
RECIEVER:
//Libraries
#include <SPI.h>
#include <RF24.h>
#include <LiquidCrystal.h>
RF24 radio(7, 8);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//FOR STOPWATCH
double i = 0;
double a = millis();
double c ;
int Input_Sensor = 9;
//FOR BEEPER
int Speaker = 6;
//DEFINE FUNCTIONS
radio.begin();
radio.openReadingPipe(0, rxAddr);
radio.startListening();
pinMode(Input_Sensor,INPUT);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print(" -STOP WATCH V1-");
a = millis();
if(digitalRead(Input_Sensor) == LOW)
char text[32] = {0};
do
c = millis();
i = (c - a) / 1000;
lcd.setCursor(0, 1);
// print the number of seconds since reset:
Serial.println(i);
lcd.print(i);
lcd.print(" Sekunden");
//if (radio.available())
radio.read(&text, sizeof(text));
Serial.println(text);
}while(text[0] != 'S');
//BEEP FUNCTION FOR SPEAKER
Actually, it's your second, but don't worry, I deleted its equally badly-posted twin.
yes first one was at the wrong folder...but thank you "awol" for this useful information...
Hi
Can you go back and please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom... :slight_smile:
Please modify your Original Post and use the code button </>
so your program looks like this
and doesn't have any smileys.
When you do that I will look at the code.
...R
Hi Guys,
MY PROBLEM NOW:
Here the Code:
TRANSMITTER:
#include <SPI.h>
#include <RF24.h>
RF24 radio(7, 8);
//FOR BEEPER
int Speaker = 2;
//FOR SENSOR
char test[] = "S";
//SETUP
  radio.begin();
//DEFINE FUNCTIONS
//LOOP
    BEEP(200);
RECIEVER:
//Libraries
#include <SPI.h>
#include <RF24.h>
RF24 radio(7, 8);
//FOR STOPWATCH
double i = 0;
double c ;
//FOR BEEPER
int Speaker = 6;
//DEFINE FUNCTIONS
  radio.begin();
  lcd.begin(16, 2);
a = millis();
  do
    c = millis();
    i = (c - a) / 1000;
    Serial.println(i);
    lcd.print(i);
I couldn't see how your new thread differed from your original one, so I merged them
okey, thx
and do you have experience´s with this problem?
How are you powering your Arduinos when they are not connected to the PC (volts and amps).
Can you try, in turn, Rx connected to PC and Tx powered separately and Tx connected to PC and Rx powered separately and tell us what happens in each case.
...R
You need to power arduino with more than 7 Volts. Check this.
