Digital Temperature Compensation of Strain Gauge Network
I'm trying to come up with a way to digitally compensate/correct the temperature shift/changes of strain gauge networks to improve accuracy and display it to the user.
I'm planning on using an Arduino Uno and some type of a transducer to read the ambient temperature, and the analog output signal of the strain gauge/bridge network, convert it to digital, predict the temperature shift and correct it.
I just need some opinions and advice on where to start and how to implement it?
Thank you.
You will first need to choose a transducer appropriate for your project.
Then, you will need to determine how the transducer parameter changes with temperature. That information may be in the transducer data sheet.
If you use a Wheatstone bridge with four transducers, temperature induced parameter variations can cancel, to a good approximation.
Good read here:
jremington:
jremington:
Thank you for your reply. Yes, I know there are ways of cancelling temperature drift physically or in the circuit itself, however, my goal is to not do any modifications to a regular resistor/strain-gauge bridge model and to cancel the temperature drift digitally using an Arduino by taking the signal of the network...
My main issue is that I don't know where to start and how to start. :slight_smile:
The procedure was given in reply #1.
