Digital Thermometer (2x 74hc595 and LED Display)
Hello,
after getting started with arduino and reading some tuts and posts and trying things out - today I proudly present my first selfmade gadget :wink:
I had a two digits LED Display lying around that I wanted to control it with my new arduino duemilanove. So I connected it up to two shift registers and figured out how to let it count from 0 up to 99. And today I looked for a useful purpose of "my display" so I worked hard to find out how to use it as an Thermometer.
It has only a range from 0 to 99 °C but I think it works. Have a look at my sketch and tell me where to optimize it:
You may want to have a look at my blog for a picture of it: http://cojakewi.blogspot.com/
//  Name    : Digital Thermometer with Shift Register & LM35    //
//  Author  : Jan www.cojakewi.de                                         //
//  Date    : 02.02.2010                                                        //
//  Version : 1.0        //
//  Notes   : Code for using a 74HC595 Shift Register             //
//          : to control a 2 digit 7 segment LED Display             //
//          : to build a digital Thermometer                             //
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
//digit is the array for numbers 192 for 0, 249 for 1,... 255 for nothing and 191 for -
byte digit[] ={192, 249, 164, 176, 153, 146, 130, 248, 128, 144, 255, 191};
int d = 1000;//delay time
int dig1;
int dig2;
int tempPin = 0;// LM35 Pin
float temperature = 0;
  //set pins to output because they are addressed in the main loop
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  Serial.println("cojakewi digital thermometer");
  dig1 = 11;
  dig2 = 11;
  anzeige();
  delay(d);//wait a d
  analogReference(INTERNAL); //for Temp
  temp();
void temp() {
  int span = 20;
  int aRead = 0;
  for (int i = 0; i < span; i++) {
    aRead = aRead+analogRead(tempPin);
  aRead = aRead / 20;
  temperature = (100*1.1*aRead)/1024;
  temperature = constrain(temperature, 0, 99);// t>0 and <99 because of display range
  Serial.print("Temperatur: ");
  Serial.println(long(temperature));
  if (temperature<10) {
      dig1 = 10; //show nothing
      dig2 = temperature; //ones
      anzeige();
   else {
      dig1 = temperature/10; //first digit tens
      dig2 = temperature - dig1*10; // second digit ones
      anzeige (); // Programm to run
   delay(d);
void anzeige () { //controls the display with shift registers
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, MSBFIRST, digit[dig2]); //ones
  shiftOut(dataPin, clockPin, MSBFIRST, digit[dig1]); //tens
  digitalWrite(latchPin, HIGH);
VEry good - I need to learn more about shift regristers. I've been using a LCD display because it's easy to write to.
Ken H>
