Digital thermostat
HI, i am planning to make a dual digital thermostat (and maybe humidity control ) using and arduino uno and a display shield ( Gravity: 1602 LCD Keypad Shield For Arduino Gravity: 1602 LCD Keypad Shield For Arduino - DFRobot)
So far so good i know how to use the temperature sensors and the display.
But i want to complicate the thing :slight_smile:
I want to make 3 pages one for each temperature/humidity and use a bottom to scroll it.
And make a settings page where i can adjust the temperatures/humidity, and for finish save the target values on eeprom, (if we got a power loss and have changed the target temp).
does anyone have something like this already made ? or can help me out ? pointing me on the correct direction ?
tanks
You would need four buttons: one to scroll through the menu, one to function as select- enter button, two for plus and minus..
You could alternatively go with a rotary encoder and a button or two.
Either way it's totally doable. If you want to consult further please let me know
Hello mugambi
The shield have 5 buttons so it can be done.
If you can help me i would appreciate!
Sending PM.
