Digital voltmeter.
Hey everyone, I'm looking to make a digital voltmeter to read up to 24v (though for this use 12-16v is nominal), with a switch. I'd also like to add a temperature sensor to read the voltage temperature (infrared, maybe?) if possible, but I'm not sure if this seems feasible or not.
I have an Arduino Uno, an oled screen (tested with a couple different libraries), a pir sensor, and a couple voltage divider circuits (with up to 8 inputs). I still need to get a switch, but wanted to go about sketching out the details more first.
Id imagine I'd essentially just do an analogRead from a pin and use functions to calculate the value from it, but im not sure how to use voltage divider a and would like to know if I may be overlooking anything else in the planning process. Thanks!
Voltage divider 1:23; read using the internal 1.1V reference for added stability and acuracy. Then indeed just analogRead() on that pin and calculate the voltage.
No idea what “voltage temperature” is.
wvmarle:
No idea what "voltage temperature" is.
Thanks, that's certainly a helpful start, will do a bit more homework and come back with some questions (or hopefully solutions). And yeah, i thought that seemed odd as well, I'm just doing this at the request of a friend to emulate what something else on the market does. Might have to do more homework on that and see how it does it, then. Thanks!
