Digital write not working on DUE but same code works Uno and Mega 2560
The following code works great on UNO and Mega 2560. It is a driver for an Elechous dual channel motor driver. I am using it to drive linear actuators with a joystick. the condition loops work but digital write pins do go high when required. see asterisks in code. Any help would be much appreciated
int SignalA= (0);//define input signal pin
int SignalB= (0);//define input signal pin
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
// default mode is INPUT
void LaIn()// Linear Actuator A IN
digitalWrite(2, HIGH); // in
digitalWrite(5, HIGH); // in
analogWrite(3,1); // in
void LaOut()// Linear Actuator A Out
digitalWrite(2, HIGH); // out
digitalWrite(3, HIGH); // out
analogWrite(5,1); // out
void LaStop()// Linear Actuator A STOP
digitalWrite(2, HIGH); // stop this pin goes high*************
digitalWrite(3, HIGH); // stop ********************this pin and pin 5 do not ******************
digitalWrite(5, HIGH); // stop
Serial.print(“hello”);
Serial.print("\t");
void LbIn()// Linear Actuator B IN
digitalWrite(8, HIGH); // in
digitalWrite(6, HIGH); // in
analogWrite(9,1); // in
void LbOut()// Linear Actuator B Out
digitalWrite(9, HIGH); // in
analogWrite(6,1); // in
void LbStop()// Linear Actuator B STOP
digitalWrite(8, HIGH); // stop
digitalWrite(9, HIGH); // stop
digitalWrite(6, HIGH); // stop
digitalWrite(0, LOW);
digitalWrite(4, LOW); // set pin low
digitalWrite(7, LOW); //
SignalA=(analogRead(A0));
SignalB=(analogRead(A5));
Serial.print(SignalA);
Serial.print("\t");
Serial.print(SignalB);
Serial.print("\t");
Serial.println(" ");
if (SignalA > 900)
LaIn();
if (SignalB > 900)
LbIn();
if (SignalA < 400)
LaOut();
if (SignalB < 400)
LbOut();
if (SignalA > 400 && SignalA < 900)
LaStop();
if (SignalB > 400 && SignalB < 900)
LbStop();
delay(10);
