DigitalInput Latency
Hi. I am currently working with arduino and Max/Msp communication.
I write simple analog and digital input code on Arduino, and send serial data to Max/Msp via Processing OSC protocol.
But, about 500ms latency happens in every digital inputs.
I use an accelerometer sensor and IR sensor,or four buttons.
Here is the code.
If somebody can solve this problem, could you answer my question :’(?
Here is the code:
Arduino:
int a = {0,0,0,0,0};
int d = {0,0,0,0};
void setup(){
Serial.begin(19200);
pinMode(0,OUTPUT);
pinMode(1,OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
pinMode(4,INPUT);
pinMode(5,INPUT);
//pinMode(7,INPUT);
void loop(){
for(int k = 0; k < 4;k++){
a[k] = analogRead(k);
Serial.print(a[k],DEC);
Serial.print(",");
for(int k = 0; k< 4;k++){
d[k] = digitalRead(k+2);
if(k != 3){
Serial.print(d[k],DEC);
Serial.print(",");
}else{
Serial.println(d[k],DEC);
//d0 = digitalRead(0);
Processing:
import processing.serial.;
import oscP5.
import netP5.*;
int linefeed = 10;
Serial myPort;
OscP5 oscP5;
NetAddress myRemoteLocation;
println(Serial.list());
frameRate(60);
/* start oscP5, listening for incoming messages at port 12000 */
oscP5 = new OscP5(this,12000);
myRemoteLocation = new NetAddress(“127.0.0.1”,12000);
myPort = new Serial(this, Serial.list()[0],19200);
myPort.bufferUntil(linefeed);
void draw(){
void serialEvent(Serial myPort){
OscMessage myMessage = new OscMessage("/test");
String myString =
myPort.readStringUntil(linefeed);
if(myString != null) {
myString = trim(myString);
int sensors = int(split(myString, ‘,’));
for (int sensorNum = 0;
sensorNum < sensors.length;
sensorNum++) {
myMessage.add(sensors[sensorNum]); /* add an int to the osc message */
oscP5.send(myMessage, myRemoteLocation);
//print(“Serial” + sensorNum + sensors[sensorNum] + “\t”);
println();
Half-a-second sounds a bit high, but all that serial stuff can't help. Should be more like 7 or 8mS. [EDIT] Oops - should be 11 or 12mS Does the latency decrease if you increase the baud rate?
I tried to change my baud rate, but it can't help. I tested 9600 and 19200, but same latency occured. Hmmmmmmm.....
Nothing I can see in that code would give you that much latency. Are you using windose, that can introduce a large chunk due to the way the serial port is handled.
