DigitalIO.h and SD.h Library Errors
I am getting a conflict between two libraries, and I need both of them in a larger program.
Board is a RobotDyn MEGA2560
IDE is 1.8.10
The libraries were installed by the Library Manager and links from the More info are:
SD.h. SD.h
DigitalIO.h DigitalIO (greiman with fastPinMode fix)
// The ATmega2560 in the Mega2560 has larger memory space :
// Flash  256k bytes (of which 8k is used for the bootloader)
// SRAM   8k bytes
// EEPROM 4k byte
// Libraries used
#include <SD.h>
#include <DigitalIO.h>
// Communications and SD Global Variables and compiler directives
// uncomment DEBUGH to include hardware debugging
// The arduino shield uses pins 38, 39, 40 to read buttons  and write LEDS
// Connecting the jumpers below and uncomming DEBUGH all the shield to simulate  testing
// Pin 41 is used as the select line to STB to chose Lights (high) or Buttons (low)
// UNPLUG CONNECTOR
// Jumpers on shield
// -- Pin 41 (Digital Connector simulating STB Select) to Pin 4 High is LEDs, Low is Buttons
// -- Pin 40 (Digital Connector PG1 /RD simulating SCK Serial Clock) to Pin 1 CLK
// -- Pin 39 (Digital Connector PG2 ALE simulating MISO Master In Slave Out) to Pin 3 DATK is Buttons Input
// -- Pin 38 (Digital Connector PD7 simulating MOSI Master Out Slave In) to Pin 2 DATA is LEDs Output
//#define DEBUG_STB_PIN (uint8_t) 41
//#define DEBUG_SPI_MOSI_PIN (uint8_t) 38
//#define DEBUG_SPI_MISO_PIN (uint8_t) 39
//#define DEBUG_SPI_SCK_PIN  (uint8_t) 40
//#define DEBUG_SPI_MODE (uint8_t) 2
const uint8_t DEBUG_STB_PIN = 41; //
const uint8_t DEBUG_SPI_MOSI_PIN = 38; // PD7 TO OUTPUT
const uint8_t DEBUG_SPI_MISO_PIN = 39; // PG2 ALE INPUT
const uint8_t DEBUG_SPI_SCK_PIN  = 40; // PG1 /RD OUTPUT
const uint8_t DEBUG_SPI_MODE = 2;
SoftSPI<DEBUG_SPI_MISO_PIN, DEBUG_SPI_MOSI_PIN, DEBUG_SPI_SCK_PIN, DEBUG_SPI_MODE> sspi;
unsigned long testPattern = 0xAAAAAAAA;
int K=0;
uint8_t BButtons = 255;
#define DEBUGHL 1
#define DEBUGHB 1
// Debug code when Arduino Shield is NOT plugged
// Only plugged into Arduino Shield
// Either DEBUGHL or DEBUGHB
#if defined(DEBUGHL) || defined(DEBUGHB)
// Initialization
pinMode(DEBUG_STB_PIN, OUTPUT);
digitalWrite(DEBUG_STB_PIN,LOW);
//  SoftSPI sspi;
sspi.begin();
#endif
// Main loop MAIN MAIN MAIN
#ifdef DEBUGHL
    testPattern = testPattern << 1; // Shift the 32 bit unsigned integer left 1 bit ie mul by 2 for next light
    if (testPattern == 0) { // If we have shifted thru all the lights then start again
      testPattern = 1;
#endif
// TEST CODE for Hardware
// Test method with shield hardware and hardware test jumpers AND NOT plugged
if (K>=350) {
  // about once a second
  // When STB is HIGH LIGHTS are being written to the Front Panel
  // When STB is LOW Buttons are being read (Don't overwrite)
  // aka NSTB is HIGH Buttons are being read (Don't overwrite)
  // Interrupt and overwrite Buttons when STB goes HIGH (or NSTB goes Low)
 // Assert the select for lights
  digitalWrite(DEBUG_STB_PIN, HIGH); // This will also generate a Buttons Interrupt
 #endif
 #ifdef DEBUGHL
  // Simulate sending lights to Front Panel
  // turn on a different light and shift to prepare the next light.
  Serial.print(F("Sndg lit tst pat "));
  Serial.println(testPattern, HEX);
  sspi.send(testPattern); // Simulate sending of lights
  // The next rising edge of STB should generate an interrupt to read the Lights
 #endif
   // Assert the select for buttons
   digitalWrite(DEBUG_STB_PIN, LOW);
 #endif
 #ifdef DEBUGHB
   // Simulate reading of buttons
   // Read the buttons
   BButtons = (uint8_t)sspi.receive(); // Simulate reading
   // Did we get any buttons? Should be only one zero bit
   if (BButtons!=0 && BButtons != 255) {
    // Print the buttons if any pushed
    Serial.print(F("Sim Rd of Buttons="));
    Serial.println(BButtons);
   #endif
 K=0;// Restart the ~1 second counter
K++; // Increment the ~1 second counter
#endif
delay(19);
// End of Main Loop
And here are the first few error codes:
In file included from /Users/rjj100/Documents/Arduino/libraries/DigitalIO/src/DigitalIO.h:31:0,
from /Users/rjj100/Documents/Arduino/Test_SoftSPI/Test_SoftSPI.ino:11:
/Users/rjj100/Documents/Arduino/libraries/DigitalIO/src/DigitalPin.h:47:6: error: ambiguating new declaration of 'void badPinNumber()'
void badPinNumber(void)
In file included from /Users/rjj100/Documents/Arduino/libraries/SD/src/utility/Sd2Card.h:26:0,
from /Users/rjj100/Documents/Arduino/libraries/SD/src/utility/SdFat.h:29,
from /Users/rjj100/Documents/Arduino/libraries/SD/src/SD.h:20,
from /Users/rjj100/Documents/Arduino/Test_SoftSPI/Test_SoftSPI.ino:9:
/Users/rjj100/Documents/Arduino/libraries/SD/src/utility/Sd2PinMap.h:463:9: note: old declaration 'uint8_t badPinNumber()'
uint8_t badPinNumber(void)
/Users/rjj100/Documents/Arduino/libraries/DigitalIO/src/DigitalPin.h: In function 'bool fastDigitalRead(uint8_t)':
/Users/rjj100/Documents/Arduino/libraries/DigitalIO/src/DigitalPin.h:127:6: error: ambiguating new declaration of 'bool fastDigitalRead(uint8_t)'
bool fastDigitalRead(uint8_t pin) {
/Users/rjj100/Documents/Arduino/libraries/SD/src/utility/Sd2PinMap.h:487:9: note: old declaration 'uint8_t fastDigitalRead(uint8_t)'
uint8_t fastDigitalRead(uint8_t pin) {
Anyone with a sketch using both libraries?
check this thread
It appears that both libraries have functions with the same name. The solution was to modify the DigitalIO library.
It looks like the SD library incorporated the DigitalIO library at some point so when you include both you get double declarations of some functions. If the version of the DigitalIO library already incorporated into the SD library doesn't have all the features you need you might have to edit one or both libraries to eliminate the conflicts.
