Digitally manipulating speed of DC motor
I am trying to vary the speed of a DC motor WITHOUT the use of a manual potentiometer (twisting a knob).
Is a digital potentiometer the simplest way to do this? If so, does anyone have a digital potentiometers that they recommend for a beginner? If there is an easier way to do this, can you please advise?
My ultimate goal is to vary the speed of the motor based on the quantity of light in a room (using a photoresistor).
Thanks!
Assuming it is a standard brushed DC motor, you can control it using PWM, with a mosfet and flyback diode to drive the motor from an Arduino. See http://bildr.org/blog/wp-content/uploads/2012/03/rfp30n06le-arduino-motor.png, but connect a 100 ohm resistor between the Arduino pin and the mosfet gate.
Digital pots are for signals, not power.
Thanks for the replies!
I created the circuit as shown from the link. I added in an extra 220 ohm resistor between the Arduino Pin 3 and the mosfet gate. (Didn't have a 100 ohm resistor)
I am still unable to control the speed of the motor. I'm a little confused as to how the mosfet helps us to accomplish the goal of varying the motor's speed. Can someone explain this to me?
Here is my code:
const int motorPin = 3;
void setup() { pinMode(motorPin, OUTPUT); }
digitalWrite(motorPin, 100); }
To vary the speed, you need to use analogWrite to write to the pin (not digitalWrite), passing values between 0 (off) and 255 (full speed).
Thank you. Analogwrite worked like a charm.
Best,
Dan
