digitalPinToInterrupt is not declared in this scope
Hello,
I tried to compile this code:
unsigned long beginTime = 0;
unsigned int dt = 0;
  while (!Serial);
  attachInterrupt(digitalPinToInterrupt(9), 9rising, RISING);
  Serial.println(dt, DEC);
void 9rising() {
  beginTime = micros();
  detachInterrupt(digitalPinToInterrupt(9));
  attachInterrupt(digitalPinToInterrupt(9), 9falling, FALLING);
void 9falling() {
  dt = micros() - beginTime;
But the compiler told me 'digitalPinToInterrupt' was not declared in this scope. So I looked in the pins_arduino.h file in .arduino15/packages/Intel/hardware/arc32/1.0.4/variants/arduino_101/ and I saw there was no macro or function definition for digitalPinToInterrupt.
Is there already a solution for this problem for the Arduino 101 or should I open an issue on Github?
Thank you,
S_v_L:
Hello,
  while (!Serial);
void 9rising() {
void 9falling() {
But the compiler told me `'digitalPinToInterrupt' was not declared in this scope`. So I looked in the pins_arduino.h file in `.arduino15/packages/Intel/hardware/arc32/1.0.4/variants/arduino_101/` and I saw there was no macro or function definition for digitalPinToInterrupt.
Thank you,
Have you tried to just put the number?
You can use just the pin number as @edsa suggested (this usually works with all chips where all pins are IRQ enabled).
However, I'll file a pull request to 101 core to add the digitalPinToInterrupt macro to avoid the need to change existing sketches.
I just recently bought the 101 and the digitalPinToInterrupt macro is still not working.
I can confirm that this still hasn't been corrected. Im verifying with both the Uno, Micro, and Pro Mini when it throws the error.
@facchinm , were you able to create that pull request?
Yep! define digitalPinToInterrupt for backwards compatibility by facchinm · Pull Request #237 · arduino/ArduinoCore-arc32 · GitHub
Reinstall the arduino software. I also had the same problem. I solved that by downloading and reinstalling the arduino software.
