DigitalRead does not return true values
So, I have written this sketch
void setup(){
    pinMode(7, INPUT_PULLUP);
    Serial.begin(250000);
void loop(){
     int val=digitalRead(7);
     Serial.println(val);
     delay(2);
I have wired the switch like GND->switch->pin 7
When the switch is off, digitalRead will for sometime return 1(as expected) and then randomly return a one or two zeroes.
The same thing goes when the switch is on. It returns zeroes(as expected) and then a one or two ones.
Learn about switch bounce. Mechanical switches do not switch cleanly which is why they need debouncing.
I thought of that, and I tried changing the mechanical switch with an optocoupler. The result is the same. I don't know if the problem is because of the big 3-phase transformer nearby.
Sounds like dodgy wiring to me. Take the switch and associated wiring out of the circuit leaving a bare Arduino board. What do you see when you run the program ?
UKHeliBob:
For sometime returns 1, and at some point return one or two zeroes, then ones again? This behavior is very strange to me.
With nothing, not even a wire connected to pin7 you occasionally get a reading of 0?
In that case nearby transformer or unstable power supply is very likely the cause of the problem.
Gabriel_swe:
Thanks, I will look into that.
braev:
void setup(){
void loop(){
    delay(2);
Serial baud rate of 250000 will push the Arduino to its limits.
Did you try also a lower baud rate of 9600 or 115200 maybe? Does the baud rate make a difference in your observations?
Try a 4k7 pullup on pin 7.
756E6C:
Why, when the pin is already being pulled HIGH ?
UKHeliBob:
4k7 is a considerably stronger pullup than the built-in 50k or so
