DigitalRead not working as expected
All having a weird issue. I have a program setup to look at a LOW input on pin 40. However when pin 40 has a GND connection nothing happens.
Here is the code thats not working
void garagebathfloor(){
  if (GBFHCallState = LOW){
    digitalWrite(MBGFHP, LOW);
    digitalWrite(GBFHV, LOW);
  else if (MBathFHCallState = LOW){
    digitalWrite(GBFHV, HIGH);
  else{
    digitalWrite(MBGFHP, HIGH);
However if I change GBFHCallState to EcoY1State a pin used elsewhere in program the arduino digital writes GBFHV, and MBCFHP to LOW
  if (EcoY1State = LOW){
  else{
On the next post is all the code, I have tried changing GBFHCall to a different pin and also tried changing the name of the pin with no avail
Any help is greatly appreciated! Im sure its just something simple I just cant figure out whats going on.
Thanks
Scott
Yeayy, that piece of code is useless. Probably the error is somewhere else because this part isn't that exiting. You have to post the whole code.
Sorry for the delay it would not allow me to post again since I am new. Also I cant seem to load all the code at one time. I removed the tft screen stuff
#include <TFT.h> // Hardware-specific library
#include <SPI.h>
#define CS   10
#define DC   8
#define RESET  9
TFT myScreen = TFT(CS, DC, RESET);
// Initialize outputs:
const int HPRev = 22; //GSHP Reversing Valve on when Ecobee set to cool
const int HPY1 = 23; //Main Area Heat or Cool Stage 1
const int HPY2 = 24; //Main Area Heat or Cool Stage 2
const int HPF = 25; //GSHP Fan commanded by Ecobee
const int HPDH = 26; //GSHP Dehumid commanded by Ecobee
const int Boil = 27; //Lochinvar Boil run command
//const int FFHP =28; //no longer used Ecobee will do floor and air handler in main area
const int MBFHP = 29; //Master Bed Floor Heat Pump
const int MBGFHP  = 30; //Master bath and garage bath circulator pump
const int GBFHV = 31; //On manifold valve for garage bath
const int MBFHV = 32; //On manifold valve for Master Bath
const int HPCirc = 33; //Ground Source Heat Pump (Source water pumps)
const int MFLCirc = 34; // Main Area Floor Heat Circ Pump
const int AHCirc = 35; //Plenum Heat Xchanger Circ Pump
// Intialize Inputs:
const int EcoRev = 41; //Ecobee reversing valve
const int EcoF = 42; //Ecobee Fan
const int EcoY1 = 43; //Ecobee Y1 call for heat (main floor heat) or AC stage 1
const int EcoY2 = 44; //Ecobee Y2 call for heat (Y1 and Y2 on Air Handler Heat on) and Cool (Y1 and Y2 on Stage 2 cooling)
const int EcoDH = 45; //Ecobee Dehumid Call
//const int FFHCall = 46; // no longer used Ecobee will do floor and air handler in main area
const int MBedFHCall = 47; //Bed room floor heat call (includes master bed, upstairs spare bed, hallway, and hall bath
const int MBathFHCall = 48; //Master bathroom call for floor heat
const int GBFHCall = 40; //garage bathroom call for floor heat
//Changed garage bath call to 40 to troubleshoot
// Variables that will change:
int EcoRevState = 0;
int EcoFState = 0;
int EcoY1State = 0;
int EcoY2State = 0;
int EcoDHState = 0;
int MBedFHCallState = 0;
int MBathFHCallState = 0;
int GBFHCallState = 0;
int BoilState = 0;
int lastEcoRevState = 0;     // previous state of the button
unsigned long previousMillis = 0;
unsigned long MBAirHand = 10000;
void setup(){
myScreen.begin();
  myScreen.background(0,0,0); // clear the screen
  myScreen.stroke(255,0,255);
  // static text
  myScreen.text("680 Fairview HVAC",0,0);
  // increase font size for text in loop()
//Drive all relays to High to begin
digitalWrite(HPRev, HIGH);
digitalWrite(HPY1, HIGH);
digitalWrite(HPY2, HIGH);
digitalWrite(HPF, HIGH);
digitalWrite(HPDH, HIGH);
digitalWrite(Boil, HIGH);
//digitalWrite(FFHP, HIGH); // no longer used Ecobee will do floor and air handler in main area
digitalWrite(MBFHP, HIGH);
digitalWrite(MBFHV, HIGH);
digitalWrite(HPCirc, HIGH);
digitalWrite(MFLCirc, HIGH);
digitalWrite(AHCirc, HIGH);
pinMode(HPRev, OUTPUT);
pinMode(HPY1, OUTPUT);
pinMode(HPY2, OUTPUT);
pinMode(HPF, OUTPUT);
pinMode(HPDH, OUTPUT);
pinMode(Boil, OUTPUT);
//pinMode(FFHP, OUTPUT); //no longer used Ecobee will do floor and air handler in main area
pinMode(MBFHP, OUTPUT);
pinMode(MBGFHP, OUTPUT);
pinMode(GBFHV, OUTPUT);
pinMode(MBFHV, OUTPUT);
pinMode(HPCirc, OUTPUT);
pinMode(MFLCirc, OUTPUT);
pinMode(AHCirc, OUTPUT);
  // Pin Inputs to Inputs:
pinMode(EcoRev, INPUT_PULLUP);
pinMode(EcoF, INPUT_PULLUP);
pinMode(EcoY1, INPUT_PULLUP);
pinMode(EcoY2, INPUT_PULLUP);
pinMode(EcoDH, INPUT_PULLUP);
//pinMode(FFHCall, INPUT_PULLUP); //no longer used Ecobee will do floor and air handler in main area
pinMode(MBedFHCall, INPUT_PULLUP);
pinMode(MBathFHCall, INPUT_PULLUP);
pinMode(GBFHCall, INPUT_PULLUP);
  EcoRevState = digitalRead(EcoRev);
  EcoY1State = digitalRead(EcoY1);
  EcoY2State = digitalRead(EcoY2);
  EcoFState = digitalRead(EcoF);
  EcoDHState = digitalRead(EcoDH);
  MBedFHCallState = digitalRead(MBedFHCall);
  MBathFHCallState = digitalRead(MBathFHCall);
  GBFHCallState = digitalRead(GBFHCall);
  BoilState = digitalRead(Boil);
//mainfloorheat();
forcedairheat();
masterbedroomfloor();
masterbathfloor();
garagebathfloor();
tftscreen();
  void tftscreen(){
//void mainfloorheat(){
  //Ecobee Heat
  //Heat Stage 1
  //if (EcoRevState == HIGH && EcoY1State == LOW && EcoY2State == HIGH){
    //digitalWrite(Boil, LOW); //turn boiler on
    //digitalWrite(MFLCirc, LOW); //turn main circulator on
 // else {
  //  digitalWrite(Boil, HIGH); //turn off boiler
  //  digitalWrite(MFLCirc, HIGH); //turn off main floor circulator
void forcedairheat(){
    //Ecobee Heat Forced Air stage 2
    //Changed EcoY2State=LOW to HIGH, so that Y1 will call for forced air heat
    digitalWrite(AHCirc, LOW); //turn air handler circulating pump on
    digitalWrite(HPF, LOW); //turn air handler fan on
    //turn off floor heat to accomidate air handler
    digitalWrite(MBFHP, HIGH); //turn off the bedroom floor circ
    else if (MBedFHCallState == LOW && EcoY2State == HIGH) {
    else {
void masterbedroomfloor(){
  if (MBedFHCallState == LOW && EcoY2State == HIGH){ // this means there is a call for bedroom area floor heat but not a call for forced air heat by the EcoBee
    digitalWrite(MBFHP, LOW); //turn on the bedroom floor pump
  else if (EcoRevState == HIGH && EcoY1State == LOW && EcoY2State == HIGH){
  else {
    digitalWrite(MBFHP, HIGH); //turn off the bedroom floor pump
    digitalWrite(Boil, HIGH); //turn boiler off
void masterbathfloor(){
//  Master bath floor heat call
    digitalWrite(MBFHV, LOW);
  else if (GBFHCallState, LOW){
  else {
  else{
You are mixing up assignments '=' with comparisons '=='
  if (MBathFHCallState = LOW){    // <- HERE
  else if (GBFHCallState, LOW){    // <- HERE not even an assignment (value is LOW always)
  else {
  if (GBFHCallState = LOW){    // <- HERE
  else if (MBathFHCallState = LOW){    // <- HERE
  else{
Thank you,
I was going crosseyed trying to understand what was wrong. That fixed it.
Sorry for the Newbie question
It happens that one suffers from organizational blindness.
