digitalRead not working for atmega644 and mightyCore
I am using Arduino with mightyCore for software development.
I'm debugging a circuit board that has an atmega644 chip and has 3 pushbuttons (UI1, UI2, and UI3).
Each pushbutton is connected to a digital input with internal pullup.
I have verified with a DMM that these inputs are at 5V when pushbutton is not pressed and 0V when pressed.
But in this test program (button.ino) digitalRead always reports 0 whether or not the pushbutton is pressed.
It's hard to believe that a simple function like that isn't working.
Am I overlooking something simple?
//  buttons.ino  check digitalRead()
#define UI2       PIN_PC2
#define UI1       PIN_PC3
#define UI3       PIN_PC4
// init I/O pins
void iopin_init() {
  pinMode(UI1,      INPUT_PULLUP);
  pinMode(UI2,      INPUT_PULLUP);
  pinMode(UI3,      INPUT_PULLUP);
#define BAUD 115200
// startup init
  iopin_init();
  Serial.begin(BAUD);
uint8_t button1;
uint8_t button2;
uint8_t button3;
// main loop
  button1 = digitalRead(UI1);
  button2 = digitalRead(UI2);
  button3 = digitalRead(UI3);
  Serial.print(" ");
  Serial.print(button1);
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(button2);
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(button3);
  Serial.print("\r\n");
#define UI2       PC2
#define UI1       PC3
#define UI3       PC4
// init I/O pins
void iopin_init() {
#define BAUD 115200
// startup init
  iopin_init();
  Serial.begin(BAUD);
uint8_t button1;
uint8_t button2;
uint8_t button3;
// main loop
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
Hi kolaha
Your proposed fix is not correct according to this documentation:
Thanks,
Does a simple blink sketch work?
Yes
Solved by disabling JTAG fuse (changed hfuse from 0X9F to 0xDF)
Refer to this post: [SOLVED] Atmega644 - problem with digital read on pins 24 (D18) and 25 (D19)
