Not seeing the whole code and nothing but the whole code, I'd guess the OP did not include Arduino.h?
Of course digitialwrite is not needed with an esp32.
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection info for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
WiFiClient wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time rtc;
#define evtDoParticleRead ( 1 << 0 ) // declare an event
#define evtADCreading ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_RemainingMoistureMQTT;
QueueHandle_t xQ_RM;
QueueHandle_t xQ_Message;
struct stu_message
char payload [150] = {'\0'};
String topic;
} x_message;
int mqttOK = 0;
bool TimeSet = false;
bool manualPumpOn = false;
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
// clear locations
memset( x_message.payload, '\0', 150 );
x_message.topic = ""; //clear string buffer
x_message.topic = topic;
int i = 0;
for ( i; i < length; i++)
x_message.payload[i] = ((char)payload[i]);
x_message.payload[i] = '\0';
xQueueOverwrite( xQ_Message, (void *) &x_message );// send data
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
x_message.topic.reserve(150);
xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
xQ_RemainingMoistureMQTT = xQueueCreate( 1, sizeof(float) ); // sends a queue copy
xQ_RM = xQueueCreate( 1, sizeof(float) );
eg = xEventGroupCreate(); // get an event group handle
sema_mqttOK = xSemaphoreCreateBinary();
xSemaphoreGive( sema_mqttOK );
gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
io_cfg.pull_down_en = GPIO_PULLDOWN_ENABLE; // enable pull down
io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) ); //bit mask of the pins to set, assign gpio number to be configured
gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
io_cfg = {}; //set configuration structure back to default values
io_cfg.mode = GPIO_MODE_OUTPUT;
io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_4) | (1ULL << GPIO_NUM_5) ); //bit mask of the pins to set, assign gpio number to be configured
gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
gpio_set_level( GPIO_NUM_5, LOW); // deenergize valve
// set up A:D channels https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
adc1_config_width(ADC_WIDTH_12Bit);
adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 6, NULL, 1 );
xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
xTaskCreatePinnedToCore( fPublish, "fPublish", 9000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fReadAD, "fReadAD", 9000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 70000, NULL, 4, NULL, 1 );
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
} //void setup()
void fReadAD( void * parameter )
float ADbits = 4096.0f;
float uPvolts = 3.3f;
float adcValue_b = 0.0f; //plant in yellow pot
uint64_t TimePastKalman = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
float WetValue = 1.07f; // value found by putting sensor in water
float DryValue = 2.732f; // value of probe when held in air
float Range = DryValue - WetValue;
float RemainingMoisture = 100.0f;
SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
for (;;)
xEventGroupWaitBits (eg, evtADCreading, pdTRUE, pdTRUE, portMAX_DELAY ); //
adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
TimePastKalman = esp_timer_get_time(); // time of update complete
RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture = 1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
xQueueOverwrite( xQ_RM, (void *) &RemainingMoisture );
//log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
vTaskDelete( NULL );
void fPublish( void * parameter )
for (;;)
if ( xQueueReceive(xQ_RemainingMoistureMQTT, &RemainingMoisture, portMAX_DELAY) == pdTRUE )
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
} // for (;;)
} //void fPublish( void * parameter )
void WaterPump0_off()
gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
vTaskDelay( 1 );
gpio_set_level( GPIO_NUM_5, LOW); //denergize/close valve
void WaterPump0_on()
gpio_set_level( GPIO_NUM_5, HIGH); //energize/open valve
vTaskDelay( 1 );
gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
void fmqttWatchDog( void * paramater )
int UpdateImeTrigger = 86400; //seconds in a day
int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
int maxNonMQTTresponse = 12;
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 5000; //delay for mS
for (;;)
vTaskDelayUntil( &xLastWakeTime, xFrequency );
xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
mqttOK++;
if ( mqttOK >= maxNonMQTTresponse )
ESP.restart();
UpdateTimeInterval++; // trigger new time get
if ( UpdateTimeInterval >= UpdateImeTrigger )
TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fDoMoistureDetector( void * parameter )
//wait for a mqtt connection
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
int TimeToPublish = 5000000; //5000000uS
int TimeForADreading = 100 * 1000; // 100mS
uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
uint64_t TimeADreading = esp_timer_get_time();
const TickType_t xFrequency = 10; //delay for 10mS
float RemainingMoisture = 100.0f; //prevents pump turn on during start up
bool pumpOn = false;
uint64_t PumpOnTime = esp_timer_get_time();
int PumpRunTime = 11000000;
uint64_t PumpOffWait = esp_timer_get_time();
uint64_t PumpOffWaitFor = 60000000; //one minute
float lowMoisture = 23.0f;
float highMoisture = 40.0f;
for (;;)
//read AD values every 100mS.
if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
xEventGroupSetBits( eg, evtADCreading );
xQueueReceive(xQ_RM, &RemainingMoisture, 0 ); //receive queue stuff no waiting
//read gpio 0 is water level good. Yes: OK to run pump : no pump off. remaining moisture good, denergize water pump otherwise energize water pump.
if ( RemainingMoisture >= highMoisture )
WaterPump0_off();
if ( !pumpOn )
log_i( "not pump on ");
if ( gpio_get_level( GPIO_NUM_0 ) )
if ( RemainingMoisture <= lowMoisture )
//has one minute passed since last pump energize, if so then allow motor to run
if ( (esp_timer_get_time() - PumpOffWait) >= PumpOffWaitFor )
WaterPump0_on();
log_i( "pump on " );
pumpOn = !pumpOn;
//xSemaphoreGive( sema_RemainingMoisture );
log_i( "water level bad " );
WaterPump0_off();
pump goes on runs for X seconds then turn off, then wait PumpOffWaitTime before being allowed to energize again
if ( (esp_timer_get_time() - PumpOnTime) >= PumpRunTime )
log_i( "pump off " );
WaterPump0_off(); // after 5 seconds turn pump off
pumpOn = !pumpOn;
// publish to MQTT every 5000000uS
if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
xQueueOverwrite( xQ_RemainingMoistureMQTT, (void *) &RemainingMoisture );// data for mqtt publish
TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector()
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
const TickType_t xFrequency = 250; // 250mS
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelete ( NULL );
void connectToMQTT()
// create client ID from mac address
byte mac[5];
int count = 0;
WiFi.macAddress(mac); // get mac address
String clientID = String(mac[0]) + String(mac[4]);
log_i( "connect to mqtt as client %s", clientID );
MQTTclient.disconnect();
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
vTaskDelay( 250 );
count++;
if ( count == 5 )
ESP.restart();
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( topicOK );
void connectToWiFi()
int TryCount = 0;
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 4000 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void fparseMQTT( void *pvParameters )
struct stu_message px_message;
for (;;)
if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
if ( px_message.topic == topicOK )
mqttOK = 0; // clear mqtt ok count
if ( !TimeSet )
String temp = "";
temp = px_message.payload[0];
temp += px_message.payload[1];
temp += px_message.payload[2];
temp += px_message.payload[3];
int year = temp.toInt();
temp = "";
temp = px_message.payload[5];
temp += px_message.payload[6];
int month = temp.toInt();
temp = "";
temp = px_message.payload[8];
temp += px_message.payload[9];
int day = temp.toInt();
temp = "";
temp = px_message.payload[11];
temp += px_message.payload[12];
int hour = temp.toInt();
temp = "";
temp = px_message.payload[14];
temp += px_message.payload[15];
int min = temp.toInt();
rtc.setTime( 0, min, hour, day, month, year );
log_i( "%s ", rtc.getTime() );
TimeSet = true;
// manual pump control
if ( str_eTopic == topicPumpState )
if ( String(strPayload) == "off" )
WaterPump0_off();
if ( String(strPayload) == "on" )
WaterPump0_on();
manualPumpOn = true;
} //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
