digitalWrite LOW not working
So I've been working on a robot that has to navigate through a course and search for a candle to put out. The robot navigates by using sensors and is driven by two rear wheels. I was able to get the code working perfectly but when I returned to my robot it no longer worked. I am fairly certain that this new problem is not an issue with the code. Whenever I set motor 1 and/or motor 2 to LOW, the motor/wheel will alternate between forwards and backwards rather than staying backwards. This is only an issue when the motor is set to LOW.
digitalWrite(motor1, HIGH); //Sets forward direction M1
digitalWrite(motor2, LOW); //Sets backward direction M2
analogWrite(E1, speed); //Full speed ahead M1
analogWrite(E2, speed); //Full speed ahead M2
In this sample of my code (turning), motor1 will go forwards and motor2 will alternate rotating forwards and backwards. I have absolutely no idea how to fix this problem, I have tried different versions of arduino, replaced the arduino board, and have fiddled with the code. Please help!!!
Can you please post a complete example program that shows the problem rather than just part of one. How are the motors and the Arduino powered ?
