digitalwrite multiple leds via button
hey guys im trying to set up 5 leds that come on for 5 different amount of time when a psuh button is pressed. i manged to get one working but having problem writing the code for mutiple leds.
(also with new code would this work leds simultaniously or one at a time, hopeing all togther)
im sorry for the stupid question
thanks
#define LED 12
#define BUTTON 7
pinMode(LED, OUTPUT); // output for the LED
 pinMode(BUTTON, INPUT); // input for the button
 if ( digitalRead(BUTTON) == HIGH )
 digitalWrite(LED, HIGH); // turn on the LED
 delay(500); // wait for 0.5 seconds
 digitalWrite(LED, LOW); // turn off the LED
My attempt at making it for multiple Leds(
#define LED8
#define LED9
#define LED10
#define LED11
#define BUTTON 7
pinMode(LED8, OUTPUT);
pinMode(LED9, OUTPUT);// output for the LED
pinMode(LED10, OUTPUT);
pinMode(LED11, OUTPUT);
 digitalWrite(LED8, HIGH); // turn on the LED
 delay(1000); // wait for 0.5 seconds
 digitalWrite(LED8, LOW); // turn off the LED
 digitalWrite(LED9, HIGH); // turn on the LED
 digitalWrite(LED9, LOW); // turn off the LED
 digitalWrite(LED10, HIGH); // turn on the LED
 digitalWrite(LED10, LOW); // turn off the LED
 digitalWrite(LED11, HIGH); // turn on the LED
 digitalWrite(LED11, LOW) // turn off the LED
The last } in above closes the block that depends on the state of the button. Anything after that } will not depend on the state of the button and will be executed unconditionally.
Im new to arduino so im still learning, ive looked everywhere for a tutorial
and no delta g i dont want them all going off at same time, im trying to get them to all stay on for individual time delays.
Have a look at how the LED timing is controlled in the demo Several Things at a Time
...R
I was going to describe how to do it but in the end wrote an example
const byte buttonPin = A1;
const byte ledPins[] = {3, 5, 6, 9};
unsigned long periods[] = {1000, 1500, 2000, 5000};
unsigned long startTime;
unsigned long currentTime;
boolean running = false;
  pinMode(buttonPin, INPUT_PULLUP);
  for (int pin = 0; pin < 4; pin++)  //set pinMode()s for the LEDs
    pinMode(ledPins[pin], OUTPUT);
    digitalWrite(ledPins[pin], HIGH); //turn off leds at the start
  if (!running) //read the input only if not already running the sequence
    if (digitalRead(buttonPin) == LOW) //button pressed
        digitalWrite(ledPins[pin], LOW);  //turn on all the leds
      startTime = millis(); //save the time we started
      running = true;   //flag that the sequence is running
  else    //actions to take only when the sequence is running
    currentTime = millis();
    for (int led = 0; led < 4; led++)  //test whether each led has been on long enough
      if (currentTime - startTime >= periods[led])
        digitalWrite(ledPins[led], HIGH); //turn off this led when period has been reached
        if (led == 3) //if this is the final led
          running = false;  //change state so that we can start again when the button is pressed
Note that the example uses 4 LEDs and that the logic may be reversed to that of your system so will need changing
Using arrays allows the code to be shorter and using millis() for timing allows the loop() function to keep running freely with no blocking such as would be caused by using delay()
See Using millis() for timing. A beginners guide, Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
