digitalWrite not works
Hi, using digitalWrite(13, HIGH); from a sample code LED blink on board does not have effect in my code ; i.e. LED still be off.
My code comes from SD datalogging sample and works perfectly.
In the setup() function a pinMode(13; OUTPUT); directive was entered and after
digitalWrite(13, HIGH); was entered too.
No compiling error was found and code gone to my ARDUINO UNO perfectly with SD gestures without errors but LED on board still not have effect.
Using a separate code from IDE samples i.e. led blink, shows that there are not hardware problem thus LED behaviour is lighting and off alternating.
Any suggest will be appreciated thanks.
You are required to post your code when using this forum!
Mark
antonio1234:
Don't try to use pin-13 TWICE for different things!
When using the SD library with an UNO board, then pin-13 will be used for the "SPI-clock" signal!
You cannot use the same pin to control your LED as you like!
SOLVED!
thank you so much, i agree with you.
Now after my misunderstanding evidence another pin must be use,
so facing pin 8 is a good idea that works.
I've really appreciated your interest,
my best greetings!
