digitalWrite(Pin, LOW); digitalWrite(Pin, 0); what's the difference?
can someone let me know what is the difference between
digitalWrite(Pin, LOW); and digitalWrite(Pin, 0)
at the moment i am using this code to touch a pin down to ground as it is a soundboard that uses pins touched to ground to activate a sound
  int HelloPin = 42;
  pinMode(HelloPin, OUTPUT);
  digitalWrite(HelloPin, 1);
then
  digitalWrite(HelloPin, 0);
and i want to know is there a difference between the 2 options
None. LOW is a compiler define that equals 0. The only difference is which is more readable for you.
oh ok i asked a question how to add the triggers and someone said use the 1 instead of low i thought it was different to LOW
so does this actually touch the pin to ground then?
One IS different from LOW. LOW is zero. HIGH is one.
PaulS: One IS different from LOW. LOW is zero. HIGH is one.
come on its obvious that was a typo from my first post
i ment i tought 0 and low was difernt
How would we know that your first post did not have a typo in it ? :)
Anyway
and
do the same thing, ie take the pin to ground, or very close to it, because, as has been said, LOW is defined as 0 in the Arduino environment.
LOW/false/0 all the same thing, as are HIGH/true/1. In a boolean context any non-zero value is treated as true...
For instance
  if (digitalRead (pin) == HIGH)
happens to be tautological, you just need
  if (digitalRead (pin))
Sometimes you don't want the code to have the knowledge of whether a pin is active-high or active-low bound into it, in which case use some #defines perhaps:
  if (digitalRead (BUTTON) == PRESSED)
Then all the details can be in a .h file. The same can be done for outputs so that you don't need to use LOW or HIGH in the bulk of the code at all, making it more re-usable and generic (always a good thing).
MarkT: LOW/false/0 all the same thing, as are HIGH/true/1. In a boolean context any non-zero value is treated as true...
For instance
Likewise:
 if (digitalRead (pin) == LOW)
is the same as:
 if (!digitalRead (pin))
